0 members (),
437
73
Topics49,850
Posts837,427
Posts: 411 Likes: 9
Posts: 411 Likes: 9 |
Hi, I'm wondering if anyone knows the front and rear axle weights? I know when the car is MOT'd they weight the front and back seperately but I have never actually thought to make a note of it. Now I find myself needing to know the rear axle weight with a full tank, does anyone know off hand? I'm guessing it must be less than 200 Kg's per wheel at the back and probably much less! If you guys don't know then I'm considering risking the bathroom scales and just lowering one rear wheel on but they might not take the weight
2009 4/4 Sport in Red 2022 Harley Davidson FXLRS Low Rider S 1977 Triumph Stag
Posts: 411 Likes: 9
Sorry, I should have said it's a 4/4 with the Sigma engine.
Posts: 8,667 Likes: 408
Posts: 8,667 Likes: 408 |
Not sure how long there has been a requirement for these loading plates but this from my Roadster. ![[Linked Image]](https://i.imgur.com/bYwKTDF.jpg)
Posts: 2,087 Likes: 70
Posts: 2,087 Likes: 70 |
As these are quoted as “maximum” weights, I assume they bear little relation to actual weights on the axles, which will of course depend on occupants, fuel, etc. The registration document for my +4 states 1400kg. The sales brochure quoted kerb weight as only 920 kg but with max total weight (including passengers, luggage etc) as 1400 kg. Quite a spread!
Posts: 12,257 Likes: 317
Posts: 12,257 Likes: 317 |
I weighed my 4/4 a few years back:
Front left = 191 kg Front right = 200 kg Front 391 Rear right = 235 kg Rear left = 240 kg Rear 475 Total Weight = 866 kg wet with tools
The method I used was to use a pair of bathroom scales with a plank on them and weighed one corner at a time, repeating it a few times and averaging it out. Not amazingly accurate, but good enough for my purposes at the time.
Posts: 375 |
2005 PLUS 4 with full tank and a 75kg tester on board during the French MOT:
Front: 402 kg Rear: 553 kg
Total with driver: 955 kg Total without driver: 880 kg
Regards 2005 PLUS 4
Posts: 27,809 Likes: 749
Posts: 27,809 Likes: 749 |
Front 560kg Rear 840kg These are max weights with total max weight 1400. This is interesting as this is my 2014 Brooklands Roadster so basically the same car as Richards but with an extra 40kg on the rear.
Posts: 411 Likes: 9
Wow, that's a bit more than I thought!  If I assume 250Kg's on each rear wheel I guess I'm not going to be far out then. Thank you for your help, especially to Hamwich as now I don't need to smuggle our bathroom scales out and down to the garage
Front 560kg Rear 840kg These are max weights with total max weight 1400. This is interesting as this is my 2014 Brooklands Roadster so basically the same car as Richards but with an extra 40kg on the rear. Leaf springs allow greater loading maybe ![[Linked Image]](https://www.series2club.co.uk/new_forum/Smileys/wittsends/nixweiss.gif)
