SORN
New
Topics48,375
Posts813,508
Members9,215
Posts: 7,948 Likes: 218
Posts: 7,948 Likes: 218 |
Having replaced mine for Caterham black ones that also have spring clip securing, can anyone recommend an easy way to remove them from the splined driveshaft. The spring tab is difficult to access, but I guess it needs to be pulled outwards.
Posts: 6,063 Likes: 161
Posts: 6,063 Likes: 161 |
Having replaced mine for Caterham black ones that also have spring clip securing, can anyone recommend an easy way to remove them from the splined driveshaft. The spring tab is difficult to access, but I guess it needs to be pulled outwards. On mine, it was just a straight pull - didn't need any levering or fiddling with the tab. However I have a folding screen so they are on and off reasonably often. Just bought a little stubby phillips to keep in the glovebox to remove them now I've swapped to screw fitted ones.
1972 4/4 4 seater, 1981 MGB GT 1984 Harley Davidson Electra Glide, 1990 Kawasaki ZX10
Posts: 697 Likes: 7
Posts: 697 Likes: 7 |
I pushed a small electrical type screwdriver between the wiper and arm. The wiper then came of easily with just a little jiggling.
Posts: 1,470 Likes: 7
Posts: 1,470 Likes: 7 |
Had to use my wipers with the 6 inch blades today in a heavy downpour mixed with hail. Must confirm they are really excellent. Can recommended them.
Posts: 281 Likes: 3
Posts: 281 Likes: 3 |
I agree too, much better quality. Why doesn't the factory fit these? I did fine tune each arm by bending the bit in the pic below but they function and park beautifully. ![[Linked Image]](https://dl.dropboxusercontent.com/s/1etms7h6csq8n6c/wiper.jpg) Roger that is perfect parking . Owen yours over lap on to the bottom of the windscreen fame . It may be possible to bend the arms to get them parallel with the bottom of the screen then adjust the arm on the splines to re position. but the arms are different ,no screw to lock them in place so It must be on a splined taper wheel box ,it’s never straight forward with a Morgan . Perhaps leave well alone if they work ok ,the rubbers can be easily replaced . Well I blame the other Peter when he fitted them originally, this picture was taken of my 4/4 when it was in dispatch (lacks a bit of clarity) and he seems quite pleased with himself ![[Linked Image]](https://www.tm-img.com/images/2020/10/10/001.jpg)
Owen "bilibib" 1982 4/4 Twin Cam, Royal Ivory 1932 Super Sports, Duo tone(two tone)Green
Posts: 26,766 Likes: 427
Posts: 26,766 Likes: 427 |
He looks like he was stealing something and is hiding it behind his back. I love the way the posters & was slope downhill. But I bet you are well pleased to have that picture
Posts: 281 Likes: 3
He looks like he was stealing something and is hiding it behind his back. I love the way the posters & was slope downhill. But I bet you are well pleased to have that picture I sure am ! ! He's hiding a fourth wiper blade, he tried to fit that one as well
When did they change from two to three.blades? I feel abit aggrieved at only having two.
Posts: 35,802 Likes: 476
Posts: 35,802 Likes: 476 |
At the launch of the Plus 8 so around 1968 I believe, the three wipers and spot lamps were easy identifiers if you couldn't hear it or see it disappearing into the distance. The others followed through commonality at production level I guess.
Posts: 1,639 Likes: 20
Posts: 1,639 Likes: 20 |
He looks like he was stealing something and is hiding it behind his back. He's just knocked the passenger mirror off reversing it in.
Roger 2011 Plus 4
