Morgan Aero 8
1 members (scortroadster), 299 guests, and 97 robots.
+8Rich 77
Topics49,870
Posts837,667
Rudolf
Page 13 of 17 1 2 11 12 13 14 15 16 17
le Asbo du Bling
le Asbo du Bling
Looks great Nick worth all the effort.
Where did you get the wiper blades from.
Slowly going green
NickCW Offline OP
Originally Posted by Alistair
Are you able to get the windscreen wipers to actually rest/end sweep on the glass or do they "park" on the trim/body?
Mine park on the trim and it shreds the rubbers and drives me just a little bit nuts.
The wipers (just) stay within the windscreen, its tight at both swept ends but worse at the scuttle area. It stays off the paint by about a mm, and took a little fettling to get right!
Thanks John, I got them from MMC.
Aero 8 GTN #11
NickCW Offline OP
Well it is finally booked into the bodyshop to sort the little niggles.. should all be done by the end of the month! cheers
Aero 8 GTN #11
PJC Offline
Hopefully just in time for the sun to return!
Cheers, Paul
Formerly known as Aldermog
Nick, you have what is, in my view, the most beautiful early Aero 8 I've ever seen.
WELL DONE... now all you have to do is enjoy driving it!
NickCW Offline OP
Fingers crossed!
Thanks Peter smile
I really must make an effort to drive it more! cheers
Aero 8 GTN #11
NickCW Offline OP
A bit of an update, at the bodyshop finally to sort the few niggles.
A few pics from one of the workshops where the car has been stripped down, quite interesting to see the chassis and inner workings.
Looks rather rat-rod at the moment!
Once the paintwork is sorted, I have new leather beading, new lights, bolts, nuts, gaskets and all sorts to go back on - so should look nice and fresh. cheers
Aero 8 GTN #11
Now's the time to check the front wishbones for cracks, and deal with any loose ball joints. Its so much easier without the wings on
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
Sir S1'a'lot
Sir S1'a'lot
Yours looks a lot cleaner than mine underneath.
2002 Aero 8 S1
2023 Plus 4 (woman’s)
NickCW Offline OP
Do they crack anywhere in particular?
I will have a look, but in theory they should be ok - I had all the wishbones checked not long ago cheers
Best get out the ol polishing rag and join me for a day when the tonneau is sorted laugh2
Aero 8 GTN #11
