7 members (DaveW, +8Rich, GrumpyPa, Ritchie B, Gordon D, Themorganeer, Stevo666),
245
75
Topics49,861
Posts837,529
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Thanks for the link Javier. Bit cheesy at times but an interesting watch particularly the chassis and body being made. Definitely reassuring to see the chassis being dipped! Any way you could copy the text and paste it into this Thread? We in the USA cannot (or at least in the Seattle ares) view the video.
Posts: 3,697 Likes: 131
Posts: 3,697 Likes: 131 |
Posts: 488 |
Maybe the Jazzy got dipped because the cameras were there. Liked the "powerful battery will hold its charge for months" comment.
Posts: 1,737 Likes: 55
Posts: 1,737 Likes: 55 |
Maybe the Jazzy got dipped because the cameras were there. Liked the "powerful battery will hold its charge for months" comment. I must admit that I had the same thought. Some Jazzy's have a very thin coating so presumably have been rushed out the door to meet a deadline.
Andy
Ian, that was perfect, thank you. My jazzy must have been in the dip tank many times because it is thick and sticky with crud. In any case, back to the NVH. Here are some photos of the install so far, the test drive will happen next week some time. ![[Linked Image]](https://www.tm-img.com/images/2020/10/10/6BE8B1EB-D0CB-4C95-882B-1C104F2E3342.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/10/10/E0C91FD7-8CDD-421F-AFDB-85B59066F998.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/10/10/13F54BD3-58D3-4ECE-BBA5-EFA750946859.jpg) I notched the floor pan to go around the front BB Mount that hangs below the frame. ![[Linked Image]](https://www.tm-img.com/images/2020/10/10/AB87C24C-D347-44C0-982F-884559BB128A.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/10/10/898E407A-B42B-40B2-9EA5-C5550A0B8FEE.jpg) There was plenty of room to slide the two extra oil lines for Morgan Customs BB Cooler kit, much better than the NVH clearances. I just need to finish the hookup of the oil lines and then mess around with the ridiculous heated seat wiring. To get the tunnel off you must unplug the wiring that powers the heated seats. That all makes sense BUT the connector is waaaaay up under the battery box electrical panel area. It took two people to find it , one wiggling the cable in the cockpit and another looking to see what moved where!! It is not wonder mechanics charge so much to work on a Morgan. I will install a waterproof connector (the M3W one was not waterproof) somewhere it can be reached easily.
Posts: 27 |
From the video; ... Once the welding is complete, the chassis is ready for a bath. Ten baths in fact. This is a rust proofing process called Autophoretic coating.
First, the chassis must undergo a thorough cleaning process before finally before dipping into a vat of PVDC resin based liquid. This material protects every nook and cranny of the steel.
Finally, a technician wearing a full body suit and equipped with an independent air supply, sprays the chassis with a coating of black paint. Bright, multidirectional lighting ensured he doesn’t miss anything. ... The images from the video showing the chassis being dunked matches the pictures from ABT's web page (especially the work floor area to the right), so very likely that the ten step process and painting is done at ABT where the chassis is made rather than at the Morgan workshop. http://www.abtproducts.com/autophoretic-coating-in-the-uk/Also to note, when showing the chassis being built from steel tubing and the welding, the workers uniform/work clothes have ABT tags on them.
Thanks for that info and the link.
That statement about painted black is sort of odd because although it is black in color it sure does not look like paint, more like tar.
Posts: 2,222 Likes: 182
Posts: 2,222 Likes: 182 |
How do you guys keep the rear of your M3Ws so clean, you must have good roads to drive on not the mountain dust bowl up here?
Posts: 1,796 Likes: 5
Posts: 1,796 Likes: 5 |
It's all smoke and mirrors, mine has definitely not been dipped as there is bare metal inside the tubes.
How do you guys keep the rear of your M3Ws so clean, you must have good roads to drive on not the mountain dust bowl up here? Well, I clean it before I work on it and take photos, otherwise it would be difficult to distinguish the difference between the M3W and a farm implement. What sort of amazes me is how dirty the cockpit gets! Not quite as bad as being last in line riding through the desert chasing a string of motorcycles while dodging cactus.
