8 members (MATTMOG, Chris99, DaveK, Laurens, KBMOG, howard, Arwyn Williams, JohnHarris),
308
43
Topics48,341
Posts812,992
Posts: 1,799 Likes: 3
Posts: 1,799 Likes: 3 |
Buy your wife a good noise cancelling head set.
I did and it has made longer journeys much more relaxed for both of us.
Bob
Posts: 21,866 Likes: 167
Posts: 21,866 Likes: 167 |
Posts: 887 Likes: 28
Posts: 887 Likes: 28 |
Noise cancelling head sets work fine for me as well. Did not put too much hope in that - but it turned out to excellent!
1985 plus 4 four seater 1992 Peraves ecomobil bicycles (pedersen to recumbent)
Posts: 14,723 Likes: 149
Posts: 14,723 Likes: 149 |
If you use the Morgan for touring a "sports" exhaust may start to get annoying on a long trip. If you finish up with ringing ears at the end of a trip it is too loud and you risk hearing damage in the long term. We have a sports exhaust on our car but it has not been too loud for us but the tone and volume has been improved (lower) since I fitted a better quality and larger cat. Wind noise with the hood up is not bad but we did have a problem with the hood flapping at Autostrada speeds. I managed to fix that. See http://www.talkmorgan.com/ubbthreads.php/topics/167781/stop-the-flapThe other thing that I have done is fit the new style windscreen pillar rubbers. By fitting them over the top of the existing flat rubbers. This pushes the side screens out a little but the alignment from the sidecreens, the new rubbers and the windscreen pillars is much better. I think it gives better, and quieter, air flow. The increased pressure of the side screens against the rubbers may require some adjustment of the side screen brackets but it may also stop the side screen flutter that occurs on some cars. If you decide to remove the existing pillar rubbers be very carefull because the coating on the pillars can be pulled off  I don't have an answer to this other than the careful use of a mild solvent (lighter fluid, turps). It probably does not make much difference to wind noise but I have small neoprene pads on the top of the windscreen pillars to stop the occasional drip of rainwater that used to enter there. If ever you think to come up to Lake Como do get in touch.
Posts: 10 |
Again, thanks everyone for your kind replies. I will try some of the solutions you've brought up, this way i hope to travel in a more comfortable way. Also, i think this should allow us to have a nice trip up to Lake Como!
2009 Morgan Roadster S2
Posts: 1,493 Likes: 32
Posts: 1,493 Likes: 32 |
Also, i think this should allow us to have a nice trip up to Lake Como!  Are we organising something? When?
We seem to be headed into another partial lockdown so it might be difficult to plan something at the moment  Perhaps we should re-visit the idea in the spring for lunch in some nice place with a lake view?
Ha Ha, She does and sometimes plugs them into music on the iPhone. I prefer to listen to the Music of the Morgan. On a more serious note (pun intended)... long term exposure to noise will cause loss of hearing. My wife used to be a Hearing Aid Audiologist and when I was biking she insisted that I wore custom made earplugs to deaden the critical frequencies. I still wear them in the Morgan if I'm doing a lot of highish speed journeys especially hood and side screens off. They do reduce the wind roar but I still hear everything I need and want to. I would recommend them as they do make long journeys more relaxing. Unfortunately, SWMBO knows I can still hear her even with the earplugs in.
Bob
Posts: 9,285 Likes: 69
Posts: 9,285 Likes: 69 |
I did and it has made longer journeys much more relaxed for both of us. Does it go over her ears or is it a gag?
Posts: 2,041 Likes: 71
Posts: 2,041 Likes: 71 |
I use a cotton flying helmet in the summer (protects from the sun as well) and a leather flying helmet in the winter to protect ears from wind noise, work great and are in keeping with the Morgans.
Bruce 1964 4/4 Series V Comp (Megan) 1994 +8 (Maurice) 2013 M3W (Olga)
