5 members (+8Rich, jbk, Graham, G4FUJ, Deejay, MartO), 287 guests, and 83 robots.
+8Rich 83
Berrybrook Aero Plus8 advert
by +8Rich - 31/08/26 04:59 AM
Topics49,850
Posts837,428
#667167 14/10/20 04:59 PM
Redfate Offline OP
Hi,
Apologies if this has been discussed on here before but I could not see anything on here.
I am about to line the floor of my garage and am thinking of using interlocking floor tiles.
There are so many different manufactures and thickness's and wonder if anyone on here (I'm sure there must be) have used them and know the pro's and Con's.
I have narrowed it down to BigDug value tiles but even they work out quite dear.
https://www.bigdug.co.uk/mats-floor...ue-interlocking-vinyl-floor-tiles-p14434
Any suggestions or advise would be appreciated.
Thanks
2009 4/4 Sport in Red
2022 Harley Davidson FXLRS Low Rider S
1977 Triumph Stag
I used the same size interlocking tiles from JTF pack of 6 for just under £10, great when I fall over something and warm to sit/crawl on.
Mark
1979 4/4 crossflow engine by Colin Musgrove, twin 40’s
I bought something similar but from a company in Manningtree via Fleabay. they do car sized packs with ramped edges.
Redfate Offline OP
Hi M500, thank you for your reply, I've just looked but they look like they are EVA and isn't EVA foam?
Do you park your car on it?
Could you use a jack on it?
Thanks
1977 Triumph Stag
I used Ecotile, as they were the only ones I could find that are made in the UK. I'm very happy with them, they were easy to lay and are very tough.
I take out the tiles if I use the back to be safe
Forgot to mention - I bought the 7.6mm Ecotiles, they are solid PVC and are quite happy taking point loads like jacks.
Redfate Offline OP
Hi Hamwich,
I had contacted Ecotile and they put me onto their sister Company "Garage Floor Tile Company"
https://www.garagefloortilecompany.com/blogs/blog/interlocking-floor-tiles
Its great to hear that you have used them and like them.
In their brochure it shows a car up on axle stands and says they are ok to use with a jack. I was a little doubtful at first but if you say they are very tough thats good enough for me cheers
1977 Triumph Stag
I used commercial grade carpet tiles stuck down with carpet tile Tackifier spray adhesive
Craig Jezz
Same as Craig. Plenty available on e bay. Mine are not stuck down and dirtier but a massive improvement on painted concrete.
