1 members (Saxonian),
359
Topics49,904
Posts838,088
Posts: 132 |
I strongly advice to get Cain's swivel type fittings.
My Google ability has failed me. Link, please!
Posts: 27,840 Likes: 764
Posts: 27,840 Likes: 764 |
Here you go Wolf PerformanceCain is fitting them to my car on the 27th
Posts: 2,095 Likes: 75
Posts: 2,095 Likes: 75 |
www.wolfperformance.co.uk then go to “shop” and click on “remote greasing“
Posts: 132 |
Thank you! He's a person, not a manufacturer - that makes more sense.
He is a good guy & will help you. He is a real enthusiast for the marque.
Posts: 1,615 Likes: 1
Posts: 1,615 Likes: 1 |
Keep a good eye on the pipe. I fitted this sort of conversion to my previous Morgan and eventually found one had blocked and as I was greasing it was simply forcing a grease bubble in the pipe - I went back to grovelling underneath as I do with my current car. I think the idea is to check that greasing has worked by seeing it squeeze out of the seal.
SFG 2012 4/4 Sport
Agreed. Mine is a damper blade car so wouldn't use it. Ok so it works perfectly well on newer cars. Obviously you need to check it once in a while
SFG 2012 4/4 Sport
Posts: 521 Likes: 2
Posts: 521 Likes: 2 |
Keep a good eye on the pipe. I fitted this sort of conversion to my previous Morgan and eventually found one had blocked and as I was greasing it was simply forcing a grease bubble in the pipe - I went back to grovelling underneath as I do with my current car. I think the idea is to check that greasing has worked by seeing it squeeze out of the seal. Yes, another reason not to fit the pipes, there’s no substitute for a good grovel
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
Not if you are in a Dark hotel car park after 500 miles across Europe with your holiday clothes on.
SFG 2012 4/4 Sport
Posts: 5,470 Likes: 476
Posts: 5,470 Likes: 476 |
When touring I ever carried a pair of overalls to wear over my holiday clothes. I think that when I bought my Wanner grease gun that the advert said it could generate 2000psi (?) which seems quite a bit for a plastic tube to cope with if there was a blockage issue..?
