Topics49,872
Posts837,686
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
The fuel system can be done at anytime but if you ever thought a bevel box cooler was something you wanted then doing it at the same time you install the Bevel Box solid mount and get rid of the silly NVH then that is the time to drill and tap the BB for the top fitting. You could even drill and tap and plug the hole so once you decided on the cooler the hole would be there to mount the fitting. Just a thought. BTW, if you put the lil cooler for the engine in then doing the BB cooler at the same time makes it easier in the future not having to dismantle one to install the other.
Posts: 960 Likes: 21
Posts: 960 Likes: 21 |
