9 members (GrumpyPa, +8Rich, John V6, JohnHarris, IcePack, Chris Cosher, Graham, G4FUJ, MartinB60, RichardV6), 282 guests, and 34 robots.
Luddite 54
Topics49,904
Posts838,094
Page 2 of 4 1 2 3 4
Originally Posted by Robbie Mathisen
I strongly advice to get Cain's swivel type fittings.
My Google ability has failed me. Link, please!
Here you go
Wolf Performance
Cain is fitting them to my car on the 27th
www.wolfperformance.co.uk then go to “shop” and click on “remote greasing“
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Thank you! He's a person, not a manufacturer - that makes more sense.
He is a good guy & will help you. He is a real enthusiast for the marque.
SFG Offline
Originally Posted by Guten
Keep a good eye on the pipe. I fitted this sort of conversion to my previous Morgan and eventually found one had blocked and as I was greasing it was simply forcing a grease bubble in the pipe - I went back to grovelling underneath as I do with my current car.
I think the idea is to check that greasing has worked by seeing it squeeze out of the seal.
SFG
2012 4/4 Sport
SFG Offline
Originally Posted by PHZI
Agreed. Mine is a damper blade car so wouldn't use it.
Ok so it works perfectly well on newer cars. Obviously you need to check it once in a while
SFG
2012 4/4 Sport
Yes, another reason not to fit the pipes, there’s no substitute for a good grovel
Simon
2002 4/4
2021 Audi A1 sport
SFG Offline
Not if you are in a Dark hotel car park after 500 miles across Europe with your holiday clothes on.
SFG
2012 4/4 Sport
When touring I ever carried a pair of overalls to wear over my holiday clothes. I think that when I bought my Wanner grease gun that the advert said it could generate 2000psi (?) which seems quite a bit for a plastic tube to cope with if there was a blockage issue..?
Page 2 of 4 1 2 3 4
