7 members (JohnHarris, CooperMan, Mike D, Luddite, Hamwich, Martin W, PaulV),
431
91
Topics49,866
Posts837,600
Posts: 12 |
Hi, been a while! My speedo cable seems to be at issue. I have a small box attached along it that’s attached to the bulkhead. Seems it works from the speedo to here but not from here to the gearbox. Anyone got any ideas what this box could be? I’m the only owner since 1992 so nothing changed from factory. I don’t seem to be able to lad a picture here. Thanks
Posts: 8,678 Likes: 412
Posts: 8,678 Likes: 412 |
Likely a tiny gearbox to match main gearbox output shaft drive to speedo.
Posts: 28,901 Likes: 352
Posts: 28,901 Likes: 352 |
The speedo cable is in two parts. You have found the junction between them. As for photos, you need to host them elsewhere and then link to your post e.g. join www.tm-img.com (instructions for use are available on that web site).
Posts: 321 Likes: 3
Posts: 321 Likes: 3 |
The junction box is a transducer that provides a road speed signal to the ECU so it knows when you come to a halt, as you come to a halt with foot off the throttle the ECU keeps the revs up for a few seconds and then drops them down to idle.
--------------------------- Mike Smith
2007 +4
Posts: 12 |
