9 members (Soleng, DCH, eds, Ritchie B, DaveW, Luddite, Mike D, TalkMorgan, gazum),
315
33
Topics49,837
Posts837,286
Posts: 6,667 Likes: 433
Posts: 6,667 Likes: 433 |
I’ve owned my Morgan 3 1/2 years now, and to date I’ve spent to much money on upgrades which I’m sure I wouldn’t get back if I sold her. It’s a good job  doesn’t know she wouldn’t approve  Amen to that! My other mods include: Led bulbs front and back Twin horns |Wipac Crystals |Spots Bonnet Strap AVO Shocks 4 Pot brakes Braided Hoses Brake reaction bars Electric fan King Pin oiler Removal Clip on Bonnet stays Silicon water hoses Custom Rocker cover Big bore manifold and exhaust K&N Filter Secondary fuse box Magnecor Leads and Iridium Plugs Librands door stays Librands sidescreen steadies Smiths Clock Clutch foot rest Lowered front seat rails Wood Paneled luggage area Klaxon Horn Wood rim Steering wheel Glovebox door Double 12v sockets Map light Indicator switch Cover plate Tracker and 4G Mobile Hotspot 7" Wipers and adjustable wiper arms 4 Leaf rear springs Adjustable Armstong Dampers Panhard Rod Wider Wheels and tyres 4 seat hood levers Indicator delay buzzer 'Lights on' buzzer Fog Light Reverse Light Addtional Mini Brake lights .
Posts: 791 Likes: 143
Posts: 791 Likes: 143 |
What an interesting thread this is.
My top 3 - in no particular order: Easy-up hood stay John Taylor's round mirrors Roger's rear suspension bump stops
In addition, many of the following have added to the weight somewhat... SiFab Aluminium radiator Performance seats Brake reaction bars Stainless wire wheels 2 eared hub spinners Front wing side lights Front spotlights Stiffened front reg plate box Headlamp protection grills Extended over riders Over rider stiffener rod Wolf front valance Lockable bonnet stays Leather bonnet protection corners Stainless n/s, centre and o/s mirrors MotoLita steering wheel Bespoke steering column cowl Bespoke dashboard under tray Bespoke left foot rest Librand door checks Fused battery conditioner connection Bespoke easy-up hood stay Roger's rear suspension bump stops Morgan Luggage carrier Bespoke spare wheel location brackets Cable operated heater controls Twin horns Bespoke engine cover
Chris
2015 Plus 4 Silverlake Blue (2014 3.7 Roadster Crystal Blue) (2012 4/4 Sport Black)
Posts: 2,273 Likes: 38
Posts: 2,273 Likes: 38 |
I’ve owned my Morgan 3 1/2 years now, and to date I’ve spent to much money on upgrades which I’m sure I wouldn’t get back if I sold her. It’s a good job  doesn’t know she wouldn’t approve  Amen to that! My other mods include: Led bulbs front and back Twin horns |Wipac Crystals |Spots Bonnet Strap AVO Shocks 4 Pot brakes Braided Hoses Brake reaction bars Electric fan King Pin oiler Removal Clip on Bonnet stays Silicon water hoses Custom Rocker cover Big bore manifold and exhaust K&N Filter Secondary fuse box Magnecor Leads and Iridium Plugs Librands door stays Librands sidescreen steadies Smiths Clock Clutch foot rest Lowered front seat rails Wood Paneled luggage area Klaxon Horn Wood rim Steering wheel Glovebox door Double 12v sockets Map light Indicator switch Cover plate Tracker and 4G Mobile Hotspot 7" Wipers and adjustable wiper arms 4 Leaf rear springs Adjustable Armstong Dampers Panhard Rod Wider Wheels and tyres 4 seat hood levers Indicator delay buzzer 'Lights on' buzzer Fog Light Reverse Light Addtional Mini Brake lights . and I bet you did all those upgrades your self ?
Craig Jezz
Yep. And even made some them from scratch
Yep. And even made some them from scratch  Credit to you TBM
Craig Jezz
Posts: 12,256 Likes: 317
Posts: 12,256 Likes: 317 |
I've had my 1986 4/4 for 20 years and in descending order of benefit, I would list the following modifications
- Replaced 90bhp CVH engine with 165bhp GM Ecotec - SSL Front suspension - Mulberry aluminium radiator - Hi-Spec 4-pot front brakes - Simmonds hood and tonneau cover - 4/4 Sport 4-leaf rear springs - Tubular rear bar with telescopic dampers - Quaife ATB differential - Panhard rod - Anti-tramp bars - Front brake reaction bars - Fibreglass wings from Sid Watson - Headlamp relays - Convex door mirrors - Simmonds door top padding - 'Professional' top spec dash switches from Holdens - Sidescreen steadies from Librands - Tool tray under rear parcel shelf - Uncle Melvyn's roller steering stops Plus loads of things like stainless fasteners, braided brake lines, rebuilt/replacement parts, LED light bulbs etc which don't really count as modifications as they are basically the same spec as the old.
Posts: 988 Likes: 14
Posts: 988 Likes: 14 |
Like a lot of others my '02 +8 has a had a lot of work, but the top 3 would be:
Simmonds Hood. The car was bought as a commuter car so the "trad" hood would just not cut it. (In fact without the availability of the Simmonds Hood I would not have bought the car.)
Mark Adams Chip; The +8s were delivered with fueling systems designed to drive a 2 ton Range Rover up the side of a house. The chip delivered a more sports care like performance.
Simmonds (Kalft?) rear mirror. Within 6 months I had been through 4 rear view mirrors This is the only one that worked for me (and is rather lovely)
(If I could perhaps sneak in a fourth, it would be the Mulfab battery re-location kit that enable me to get rid of the front fitted, execrable, DMS Red Flash battery and fit a conventional battery in the "correct" position at the rear).
Oh, most useless accessory would be the MMC fitted clock. When trying to debug a 4 day battery life problem, the MMC suggested to unplug the clock. 17 years later I have still not plugged it back in.
Brian
Jersey and Spain
Posts: 396 Likes: 44
Posts: 396 Likes: 44 |
I've only made one modification to mine - and not in a tearing hurry to make many more as I like my motors "as supplied" mainly
I fitted Librands Brake Reaction Bars 2 weeks ago (one Saturday when it wasn't raining.......) So easy No need to drill anything as they line up directly with an existing nut / bolt on the chassis / tub joint line
Was surprised it was such a noticeable difference - much more of a "solid" feeling at the front end
Which did get me thinking about a panhard rod....... but do I really "need" one for burbling round the roads? I had exactly the same experience with BRBs. I then fitted a PR, and that made a related, but more pronounced change, believe me - even at slow speeds. Of course you don't need it, as you did not need the BRBs. But then who really needs a Morgan... It's all about fun, pleasure and the driving experience. But a PR is much more expensive and fiddly to fit. My best three mods: 1. Convex, round stainless steel side mirrors instead of the flat, oval alloy/bad chrome side mirrors + convex front screen SS mirror instead of flat alloy OE. 2. Brake reaction stays 3. Panhard rod By the way, excellent thread. I encourage all newcomers to read! It's strange......... I've just realised... When I bought my car 3 months ago I paid to have chrome wire wheels fitted rather than the painted stainless wire wheels (Modification No 1....) 5 weeks after delivery - I bought replacement "2 ear" knock off wheel nuts to replace the octagonal chrome ones (Modification No 2...) So I have carried out 3 modifications - but only "remembered" the cheapest - The BRB's @£40 I'm now researching Panhard Rods ............. I do fancy fitting them myself - Wish I had a decent sized garage / workshop
Ian S
2019 Sports Green Plus 4 2025 Hyper Blue Mercedes 180 CLA
Posts: 504 Likes: 2
Posts: 504 Likes: 2 |
As far as I know there are three PRs: Mulfab, SSL and SiFab, all a little different. Mulfab and SSL can be checked out on the net, but I cannot find any info on the Sifab. Mine is SSL, though - worked fine in both fitting and when driving. And excuse the thread drift.....
Robbie the Norseman 2004 V6 Roadster Sherwood green
I'm now researching Panhard Rods ............. I do fancy fitting them myself - Wish I had a decent sized garage / workshop  You don't need one  All my mods/upgrades/repairs are done on a scabby bit of conrete outside my house. ![[Linked Image]](https://www.tm-img.com/images/2020/04/02/2020-04-02-2.png)
