11 members (TBM, nick w, nestor59310, jbk, vbalddave, 2949olivier, Fuel.inj, Montegue, Image, Alan Patterson, Strathaven), 320 guests, and 40 robots.
+8Rich 92
Posts837,283
Page 4 of 11 1 2 3 4 5 6 10 11
TBM Online Content
Originally Posted by Craig Jezz
I’ve owned my Morgan 3 1/2 years now, and to date I’ve spent to much money on upgrades which I’m sure I wouldn’t get back if I sold her.
It’s a good job swmbo doesn’t know she wouldn’t approve nono
Amen to that!
My other mods include:
Led bulbs front and back
Twin horns
|Wipac Crystals
|Spots
Bonnet Strap
AVO Shocks
4 Pot brakes
Braided Hoses
Brake reaction bars
Electric fan
King Pin oiler Removal
Clip on Bonnet stays
Silicon water hoses
Custom Rocker cover
Big bore manifold and exhaust
K&N Filter
Secondary fuse box
Magnecor Leads and Iridium Plugs
Librands door stays
Librands sidescreen steadies
Smiths Clock
Clutch foot rest
Lowered front seat rails
Wood Paneled luggage area
Klaxon Horn
Wood rim Steering wheel
Glovebox door
Double 12v sockets
Map light
Indicator switch Cover plate
Tracker and 4G Mobile Hotspot
7" Wipers and adjustable wiper arms
4 Leaf rear springs
Adjustable Armstong Dampers
Panhard Rod
Wider Wheels and tyres
4 seat hood levers
Indicator delay buzzer
'Lights on' buzzer
Fog Light
Reverse Light
Addtional Mini Brake lights
What an interesting thread this is.
My top 3 - in no particular order:
Easy-up hood stay
John Taylor's round mirrors
Roger's rear suspension bump stops
In addition, many of the following have added to the weight somewhat...
SiFab Aluminium radiator
Performance seats
Brake reaction bars
Stainless wire wheels
2 eared hub spinners
Front wing side lights
Front spotlights
Stiffened front reg plate box
Headlamp protection grills
Extended over riders
Over rider stiffener rod
Wolf front valance
Lockable bonnet stays
Leather bonnet protection corners
Stainless n/s, centre and o/s mirrors
MotoLita steering wheel
Bespoke steering column cowl
Bespoke dashboard under tray
Bespoke left foot rest
Librand door checks
Fused battery conditioner connection
Bespoke easy-up hood stay
Morgan Luggage carrier
Bespoke spare wheel location brackets
Cable operated heater controls
Twin horns
Bespoke engine cover
Chris
2015 Plus 4 Silverlake Blue
(2012 4/4 Sport Black)
Amen to that!
Twin horns
|Wipac Crystals
|Spots
Bonnet Strap
AVO Shocks
4 Pot brakes
Braided Hoses
Brake reaction bars
Electric fan
Silicon water hoses
Custom Rocker cover
K&N Filter
Secondary fuse box
Librands door stays
Smiths Clock
Clutch foot rest
Klaxon Horn
Glovebox door
Double 12v sockets
Map light
4 Leaf rear springs
Panhard Rod
4 seat hood levers
'Lights on' buzzer
Fog Light
Reverse Light
and I bet you did all those upgrades your self ?
Craig Jezz
TBM Online Content
Yep. And even made some them from scratch smile
Credit to you TBM
Craig Jezz
I've had my 1986 4/4 for 20 years and in descending order of benefit, I would list the following modifications
- Replaced 90bhp CVH engine with 165bhp GM Ecotec
- SSL Front suspension
- Mulberry aluminium radiator
- Hi-Spec 4-pot front brakes
- Simmonds hood and tonneau cover
- 4/4 Sport 4-leaf rear springs
- Tubular rear bar with telescopic dampers
- Quaife ATB differential
- Panhard rod
- Anti-tramp bars
- Front brake reaction bars
- Fibreglass wings from Sid Watson
- Headlamp relays
- Convex door mirrors
- Simmonds door top padding
- 'Professional' top spec dash switches from Holdens
- Sidescreen steadies from Librands
- Tool tray under rear parcel shelf
- Uncle Melvyn's roller steering stops
Plus loads of things like stainless fasteners, braided brake lines, rebuilt/replacement parts, LED light bulbs etc which don't really count as modifications as they are basically the same spec as the old.
Like a lot of others my '02 +8 has a had a lot of work, but the top 3 would be:
Simmonds Hood. The car was bought as a commuter car so the "trad" hood would just not cut it. (In fact without the availability of the Simmonds Hood I would not have bought the car.)
Mark Adams Chip; The +8s were delivered with fueling systems designed to drive a 2 ton Range Rover up the side of a house. The chip delivered a more sports care like performance.
Simmonds (Kalft?) rear mirror. Within 6 months I had been through 4 rear view mirrors This is the only one that worked for me (and is rather lovely)
(If I could perhaps sneak in a fourth, it would be the Mulfab battery re-location kit that enable me to get rid of the front fitted, execrable, DMS Red Flash battery and fit a conventional battery in the "correct" position at the rear).
Oh, most useless accessory would be the MMC fitted clock. When trying to debug a 4 day battery life problem, the MMC suggested to unplug the clock. 17 years later I have still not plugged it back in.
Brian
Jersey and Spain
Originally Posted by Robbie Mathisen
Originally Posted by Saxonian
I've only made one modification to mine - and not in a tearing hurry to make many more as I like my motors "as supplied" mainly
I fitted Librands Brake Reaction Bars 2 weeks ago (one Saturday when it wasn't raining.......)
So easy
No need to drill anything as they line up directly with an existing nut / bolt on the chassis / tub joint line
Was surprised it was such a noticeable difference - much more of a "solid" feeling at the front end
Which did get me thinking about a panhard rod....... but do I really "need" one for burbling round the roads?
I had exactly the same experience with BRBs. I then fitted a PR, and that made a related, but more pronounced change, believe me - even at slow speeds. Of course you don't need it, as you did not need the BRBs. But then who really needs a Morgan... It's all about fun, pleasure and the driving experience. But a PR is much more expensive and fiddly to fit.
My best three mods:
1. Convex, round stainless steel side mirrors instead of the flat, oval alloy/bad chrome side mirrors + convex front screen SS mirror instead of flat alloy OE.
2. Brake reaction stays
3. Panhard rod
By the way, excellent thread. I encourage all newcomers to read!
It's strange......... I've just realised... When I bought my car 3 months ago I paid to have chrome wire wheels fitted rather than the painted stainless wire wheels (Modification No 1....)
5 weeks after delivery - I bought replacement "2 ear" knock off wheel nuts to replace the octagonal chrome ones (Modification No 2...)
So I have carried out 3 modifications - but only "remembered" the cheapest - The BRB's @£40
I'm now researching Panhard Rods ............. I do fancy fitting them myself - Wish I had a decent sized garage / workshop frown
Ian S
2019 Sports Green Plus 4
2025 Hyper Blue Mercedes 180 CLA
As far as I know there are three PRs: Mulfab, SSL and SiFab, all a little different. Mulfab and SSL can be checked out on the net, but I cannot find any info on the Sifab. Mine is SSL, though - worked fine in both fitting and when driving. And excuse the thread drift.....
Robbie the Norseman
2004 V6 Roadster
Sherwood green
TBM Online Content
You don't need one smile
All my mods/upgrades/repairs are done on a scabby bit of conrete outside my house.
