1 members (How), 341 guests, and 31 robots.
+8Rich 94
John V6 50
Posts837,997
rockabilly john
#670263 31/10/20 08:52 PM
stanley Offline OP
I am having touble shifting . First gear is touchy and downshifting into ssecond is tough. I think I might need a new clutch or transmittion fluid, any ideas?
stanley #670264 31/10/20 08:55 PM
If you provide your model and year it will help to get a more coherent reply thumbs In 110 years there are quite a few wink
stanley #670271 31/10/20 09:12 PM
stanley Offline OP
oops, 1967 4/4 . It has the ford Cortina engine. I am thinkg a new Synchromesh gear between 2 and third?
stanley #670276 31/10/20 09:44 PM
Is the gearbox oil level Ok?
Sounds like the gears to me
stanley #670289 01/11/20 01:53 AM
Do you have a decent pedal? Try bleeding your clutch slave cylinder.
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
stanley #670296 01/11/20 06:16 AM
Cable or hydraulic clutch operation?
If cable (or rod - there were a number) check the free play is not excessive.
If hydraulic I would check master / slave cylinders aren't leaking thus reducing the clutch release action.
stanley #670299 01/11/20 08:27 AM
TBM Offline
As mentioned above - do the easy stuff first. Check gearbox oil level. Flush, drain and refill. Check clutch linkage (my 72 is rod) and adjust properly.
Anything else (clutch/gearbox) is an 'engine out' job unfortunately.
stanley #670303 01/11/20 09:03 AM
Is the gear change remotely operated? I know on the Rover gearboxes the gear change is remote & if the bushes wear you can get something similar.
This might help
Gearbox
John V6 #670305 01/11/20 09:15 AM
TBM Offline
This might help
Gearbox
Good call - even if not remote, it may be something as simple as a worn ball at the end of the gearlever (I had a Land Rover that would only engage 1st or reverse if you went into 2nd gear first - a gearlever swap sorted it out).
stanley #670308 01/11/20 09:22 AM
TBM Offline
Arwyn knows his stuff with these boxes, hopefully he'll be able to diagnose accurately.
