8 members (RichardV6, Moggo, BobtheTrain, Alan Patterson, bmgermany, How, IcePack, TBM),
253
43
Posts837,993
Posts: 5 |
I am having touble shifting . First gear is touchy and downshifting into ssecond is tough. I think I might need a new clutch or transmittion fluid, any ideas?
Posts: 37,478 Likes: 988
Posts: 37,478 Likes: 988 |
If you provide your model and year it will help to get a more coherent reply  In 110 years there are quite a few
Posts: 5 |
oops, 1967 4/4 . It has the ford Cortina engine. I am thinkg a new Synchromesh gear between 2 and third?
Posts: 27,835 Likes: 761
Posts: 27,835 Likes: 761 |
Is the gearbox oil level Ok? Sounds like the gears to me
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
Do you have a decent pedal? Try bleeding your clutch slave cylinder.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 28,909 Likes: 354
Posts: 28,909 Likes: 354 |
Cable or hydraulic clutch operation? If cable (or rod - there were a number) check the free play is not excessive. If hydraulic I would check master / slave cylinders aren't leaking thus reducing the clutch release action.
Posts: 6,675 Likes: 441
Posts: 6,675 Likes: 441 |
As mentioned above - do the easy stuff first. Check gearbox oil level. Flush, drain and refill. Check clutch linkage (my 72 is rod) and adjust properly.
Anything else (clutch/gearbox) is an 'engine out' job unfortunately.
Is the gear change remotely operated? I know on the Rover gearboxes the gear change is remote & if the bushes wear you can get something similar. This might help Gearbox
Is the gear change remotely operated? I know on the Rover gearboxes the gear change is remote & if the bushes wear you can get something similar. This might help GearboxGood call - even if not remote, it may be something as simple as a worn ball at the end of the gearlever (I had a Land Rover that would only engage 1st or reverse if you went into 2nd gear first - a gearlever swap sorted it out).
Arwyn knows his stuff with these boxes, hopefully he'll be able to diagnose accurately.
