10 members (Luddite, TBM, Graham, G4FUJ, IcePack, Montegue, JohnHarris, Image, RichardV6, bmgermany, John V6), 397 guests, and 43 robots.
+8Rich 92
Posts837,278
Page 8 of 11 1 2 6 7 8 9 10 11
Does someone know where I can get the hardware to put on a bonnet strap ?
1980 + 8
Dutch Junge
194 Mound St
Logan, OH USA 43138
2012 3 Wheeler
1980 + 8
1980 + 8
As far as I'm aware there isn't any hardware required. You just put the end of the belt between the wing and the little buffer jobbie that sits between the two bonnet catches. Obvs you'd need to drill a hole in the end of the belt to bolt through. I can't illustrate that bit because my bonnet belt is at the bottom of a box at the back of the garage.
Best mod I made to my 4/4 was taking out the knackered old 87bhp CVH engine and putting in a tuned 165bhp GM Ecotec VVTi. Or to be more accurate, paying Kevin Vernon to do it for me. Other than that I've been particularly pleased with:
- Fitting hard chrome kingpins
- SSL Front suspension
- Quaife ATB 4.1:1 Diff
- Simmonds hood
- My 3D printed coin tray and water bottle holder
- Additional LED brake light strip mounted to rear luggage rack
- Tool tray under rear shelf
- Twin piston billet front brake callipers and reaction bars
- Panhard rod and anti-tramp bars
Modifications which upon reflection were a waste of time and have now been discarded:
- Wind wings
- Subwoofer behind the driver's seat
- removing the damper blades and fitting a telescopic damper
Mine ('75 crossflow 4/4) has two little strap loops that bolt through the wing .... not yet fitted my bonnet strap and assumed the strap looped round them and fastened back on itself .... now thinking that they are just a guide to feed the strap under the bonnet snug to the wing and it then bolts to the rubber snubber bracket as described above . Bit of a light-bulb moment as I wasn't looking forward to sewing through the nice stout leather straps I'd got 🙂👍
Best three mods to my '92 plus4
Audible alarm on the indicators.
Mulfab brake up grade
Adding clock
1992 plus4 connaught green
On my 3.7l Roadster
1. Gps speedo. The speedo reads 10% low and is off to the left
2. K&n air filter
3. LED headlights
4. Cruise control
5. Beeper for indicators
6. LED indicator and other bulbs
1980 + 8
I hope this picture helps
Craig Jezz
X
X
Best modifications:
Brakereaction bars, a massive step forward.
Hoodstay (homemade)
Raising up the seats
Homemade tooltray
Homemade dash with maplight
Fitting twoeared spinners
Greets René
2018 plus4 (sports green)
TBM Online Content
Best of most recent mods:
5 speed gearbox
Stainless Tank
Electric fuel pump (makes starting much easier)
- Grease gun holder box under the bonnet
- Sat nav mounting bracket
- Givi pannier mounting kit on luggage rack
- Rod mirror (easy up hood)
- Bonnet props
Costock, UK
Disco 5
