7 members (vincentvg, paulmog, James B W, John V6, lez, CharlieB, +8Rich),
222
38
Posts837,999
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
Another option for those with the tall roll-bars with built-in headrests is to add lights on the back of the headrests. I used these Dogeye Puckz and wired them as brake lights, running lights and turn signals. It makes the M3W a more visible in traffic, and they are really bright. I wired them to the brake light connector, and then tapped into the turn signals and running lights. ![[Linked Image]](https://www.tm-img.com/images/2020/11/02/221973A5-E12C-463D-9FF9-2B5B9C6C1D2A.jpg) I Like it!
Posts: 121 Likes: 1
Posts: 121 Likes: 1 |
Because what you propose is factory fit on the Australian version as above, the standard loom already includes connections for it. Look for two way connector tucked away with green/purple and black cables. You will just need the lamp pod U340032 and pedestal T400037 and drill a hole of course. Thank you Gentlemen for your help. I wasn't trying to reinvent the wheel, that is why I wanted to post this. I have contacted my dealer and he is trying to get it ordered for me. I assume the wiring harness is close to the area where the third brake light will mount??
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
By the frame down close to the gas tank on the pump side.
I wondered what that outlet was for when I changed the fuel pump
I wondered what that outlet was for when I changed the fuel pump I wondered enough to put a meter on them and found brake light. There are wires dangling at the down tube from the dash to the side cockpit tube and although I have not identified them i suspect side light power.
Posts: 557 |
I wondered what that outlet was for when I changed the fuel pump I wondered enough to put a meter on them and found brake light. There are wires dangling at the down tube from the dash to the side cockpit tube and although I have not identified them i suspect side light power. I believe Australian versions have side-markers
Posts: 121 Likes: 1
Richard is correct. I ordered those part numbers a while ago and received the following: ![[Linked Image]](https://www.tm-img.com/images/2020/11/02/P1150338.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/11/02/P1150339.jpg) I found the finish on the aluminium upstand to be poor so this will require refinishing & polishing before fitting. ![[Linked Image]](https://www.tm-img.com/images/2020/11/02/P1150340.jpg) ![[Linked Image]](https://www.tm-img.com/images/2020/11/02/P1150341.jpg) I haven't got around to fitting it yet, partly because it goes against the grain to cut a 12mm hole in the bodywork.  Also, my car is a 2012 model so will almost certainly not have the necessary electrical connector in the wiring loom. Not a big problem I guess but another reason to put the project on the back burner for now! By the way, in 2018 I paid Uncle Melvyn £38.31 for the lamp (U340032) and £8.67 for the pedestal (T400037). Both prices exclude VAT & delivery. What wire goes to what side of the connector? Does it matter?
