0 members (), 312 guests, and 22 robots.
+8Rich 94
John V6 50
Posts837,998
rockabilly john
Page 3 of 3 1 2 3
Originally Posted by JohnMat
Another option for those with the tall roll-bars with built-in headrests is to add lights on the back of the headrests.
I used these Dogeye Puckz and wired them as brake lights, running lights and turn signals. It makes the M3W a more visible in traffic, and they are really bright.
I wired them to the brake light connector, and then tapped into the turn signals and running lights.
I Like it!
Rodger
2004 Plus 8 (wife's)
Because what you propose is factory fit on the Australian version as above, the standard loom already includes connections for it. Look for two way connector tucked away with green/purple and black cables. You will just need the lamp pod U340032 and pedestal T400037 and drill a hole of course.
Thank you Gentlemen for your help. I wasn't trying to reinvent the wheel, that is why I wanted to post this. I have contacted my dealer and he is trying to get it ordered for me. I assume the wiring harness is close to the area where the third brake light will mount??
By the frame down close to the gas tank on the pump side.
I wondered what that outlet was for when I changed the fuel pump
Rodger
I wondered enough to put a meter on them and found brake light. There are wires dangling at the down tube from the dash to the side cockpit tube and although I have not identified them i suspect side light power.
I believe Australian versions have side-markers
Bunny #674918 27/11/20 01:48 AM
Originally Posted by Bunny
Richard is correct. I ordered those part numbers a while ago and received the following:
I found the finish on the aluminium upstand to be poor so this will require refinishing & polishing before fitting.
I haven't got around to fitting it yet, partly because it goes against the grain to cut a 12mm hole in the bodywork. shocked2 Also, my car is a 2012 model so will almost certainly not have the necessary electrical connector in the wiring loom. Not a big problem I guess but another reason to put the project on the back burner for now!
By the way, in 2018 I paid Uncle Melvyn £38.31 for the lamp (U340032) and £8.67 for the pedestal (T400037). Both prices exclude VAT & delivery.
What wire goes to what side of the connector? Does it matter?
Page 3 of 3 1 2 3
