1 members (Kolvites),
328
45
Posts837,990
Posts: 121 Likes: 1
Posts: 121 Likes: 1 |
Stop worrying! Just drive it! Great advice. Thank you
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
Oh dear... I am almost at 10,000 miles
I did say that they generally lasted that long and that some have lasted much more or much less, it isn't a fixed life. Don't just put your finger up the hole to check for bits of rubber, have a look inside with a small mirror on a stick and a strong light. The rubber bits usually end up at the back on the lowest point of the bellhousing and you should be looking for chunks not just dust.
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
I did say that they generally lasted that long and that some have lasted much more or much less, it isn't a fixed life. Don't just put your finger up the hole to check for bits of rubber, have a look inside with a small mirror on a stick and a strong light. The rubber bits usually end up at the back on the lowest point of the bellhousing and you should be looking for chunks not just dust. Good advice.
Posts: 557 |
assuming the larger.... but I have been known to stick a finger in the wrong hole 😂😂😂
