1 members (Socalm3w),
291
Topics48,341
Posts812,981
Posts: 1,876 Likes: 15
Posts: 1,876 Likes: 15 |
I have heard the advice.... tighten it until it breaks and then back off 1/4 turn
Posts: 285 Likes: 3
Posts: 285 Likes: 3 |
Where did the sheared off head of bolt go?
No sign of it. I assume it came off while driving as I have done about 1200 miles since I changed the air filter, and the idling problems are recent. It would have dropped between the cylinders, so I would guess it rolled out from there.
2020 M3W
When I used to race sailboats, we would sometimes toss a nut or two onto another boat. Would drive the crew crazy trying to find where it went
Posts: 265 |
When I used to race sailboats, we would sometimes toss a nut or two onto another boat. Would drive the crew crazy trying to find where it went Rodger, where/what did you race? I'm an offshore, short-handed and distance and guy myself and pull a lot of RC duty in Newport and Long Island Sound.
'17 M3W: '08 Ural Gear-Up
This was decades ago in the San Francisco area with one design boats. My dad raced Snipes, I started off with an "El Toro" which is an 8' dinghy and then in high school build an OK Dinghy which was a junior Olympic boat a wee bit smaller than a Finn.
Posts: 285 Likes: 3
For those fitting one of these filters, I recommend taking a close look at the alignment of the filter to the cylinder heads before fitting the chrome mount “arms” that support the air filter. In my case on re-assembling mine having fitted the replacement bolts and O-ring that attach the throttle body to the inlet manifold, it was clear that this alignment was well off. I suspect this was why one of my throttle body mount bolts bolts sheared off (see above) and caused the air leak, as tightening these up before must have put a lot of tension on the throttle bolts. I tried to follow kankeL’s advice on loosening the intake manifold bolts, but the lower ones are very hard to access and I could not get them loose, so instead I put a couple of bends in the mount to create an offset. It is soft enough steel that it bends easily. See below. Having finished re-assembly with copious loc-title, it is now idling and running great again. Phew! ![[Linked Image]](https://www.tm-img.com/images/2020/11/08/D9EE682F-7AEB-4092-98E1-EEED7BB01AAE.jpg)
2020 M3W
Posts: 3,854 Likes: 2
Posts: 3,854 Likes: 2 |
When I installed mine I remember something about the offset distances and spacers maybe being involved? I installed and purchased mine in July 2019.
Posts: 2,041 Likes: 71
Posts: 2,041 Likes: 71 |
When I installed my Stealth Air Filter one bracket came made with the offset the other not, so they were fitted to the appropriate side!!!
Bruce 1964 4/4 Series V Comp (Megan) 1994 +8 (Maurice) 2013 M3W (Olga)
Posts: 285 Likes: 3
When I installed my Stealth Air Filter one bracket came made with the offset the other not, so they were fitted to the appropriate side!!! Interesting. Mine were both supplied flat.
2020 M3W
