7 members (Themorganeer, Jon G4LJW, CLPlusFour, TalkMorgan, RichardV6, DJC, 1854sailor), 268 guests, and 10 robots.
John V6 69
DaveW 68
+8Rich 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Topics48,343
Posts813,026
RedThree
Page 4 of 4 1 2 3 4
I have heard the advice.... tighten it until it breaks and then back off 1/4 turn
Rodger
2004 Plus 8 (wife's)
Where did the sheared off head of bolt go?
No sign of it. I assume it came off while driving as I have done about 1200 miles since I changed the air filter, and the idling problems are recent. It would have dropped between the cylinders, so I would guess it rolled out from there.
2020 M3W
When I used to race sailboats, we would sometimes toss a nut or two onto another boat. Would drive the crew crazy trying to find where it went
Rodger
0
Rodger, where/what did you race? I'm an offshore, short-handed and distance and guy myself and pull a lot of RC duty in Newport and Long Island Sound.
'17 M3W:
'08 Ural Gear-Up
This was decades ago in the San Francisco area with one design boats. My dad raced Snipes, I started off with an "El Toro" which is an 8' dinghy and then in high school build an OK Dinghy which was a junior Olympic boat a wee bit smaller than a Finn.
Rodger
For those fitting one of these filters, I recommend taking a close look at the alignment of the filter to the cylinder heads before fitting the chrome mount “arms” that support the air filter. In my case on re-assembling mine having fitted the replacement bolts and O-ring that attach the throttle body to the inlet manifold, it was clear that this alignment was well off. I suspect this was why one of my throttle body mount bolts bolts sheared off (see above) and caused the air leak, as tightening these up before must have put a lot of tension on the throttle bolts.
I tried to follow kankeL’s advice on loosening the intake manifold bolts, but the lower ones are very hard to access and I could not get them loose, so instead I put a couple of bends in the mount to create an offset. It is soft enough steel that it bends easily. See below.
Having finished re-assembly with copious loc-title, it is now idling and running great again. Phew!
2020 M3W
When I installed mine I remember something about the offset distances and spacers maybe being involved? I installed and purchased mine in July 2019.
When I installed my Stealth Air Filter one bracket came made with the offset the other not, so they were fitted to the appropriate side!!!
Bruce
1994 +8 (Maurice)
2013 M3W (Olga)
Interesting. Mine were both supplied flat.
2020 M3W
Page 4 of 4 1 2 3 4
