5 members (Zach, IcePack, ScotiaSteve, thelastgizmo, BobtheTrain), 233 guests, and 30 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,147
#670813 04/11/20 01:53 PM
hi i am new to the group. I just received my 2017 M3W over the weekend. I did not get any documentation but one of the members sent me a copy of the
users manual. My question is: I went to check the oil level and there is not dip stick. Is there some marking inside the oil tank that shows what the oil level should be at?
I asked the dealer and they said they changed the oil before they shipped it but they put in 5 quarts of oil. From what i am reading they should have put in 6. I dont want to run a qt low so
wanted to know what the level should be looking into the tank.
2017 Betty #670817 04/11/20 02:03 PM
You can see the level if you look in the tank through the cap hole. The "MAX" oil level is in line with the forward angled plate and the "MIN" in line with the rear plate (about 1/2 " lower than "MAX"). As it is a dry sump system, check the oil level a few minutes after the engine has been run, so it scavenges the oil back to the tank
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
2017 Betty #670820 04/11/20 02:05 PM
Only check the oil when engine is warm.
There will be two plates visible when you look into the tank. They are at different levels, a minimum and a maximum level indicator for warm readings.
2017 Betty #670822 04/11/20 02:07 PM
thanks
2017 Betty #670829 04/11/20 02:18 PM
As mentioned you need to run the engine a bit as a certain amount of oil will go ack to the engine. Otherwise you will get a false low reading. Unlike a Harley, where you check the oil level HOT just running it warm enough to get all the oil back into the tank suffices.
Where are y'all from?
Rodger
2004 Plus 8 (wife's)
2017 Betty #670867 04/11/20 05:25 PM
It can be confusing if someone has overfilled the tank and the level markers are under the surface - it happened to one of my customers recently.
2017 Betty #670891 04/11/20 07:32 PM
I recall in 1978 I had a friend with a new Gold Wing. There is a very difficult to see "sight glass" on the lower right side of the engine. The friend filled the engine until he could see oil at the fill hole......WOW did that engine SMOKE
Rodger
Phil Bleazey #671080 05/11/20 06:39 PM
Phil, to add to your upgrades, how about a dip stick type oil tank cap? That way the level indicator will always be on the cap and not buried under too much oil in the tank.
Just a thought... smile
Dan
2017 Betty #671082 05/11/20 06:45 PM
Buried under oil = a massive overfill. The two bar indicators could not be clearer.
Dan_Lockwood #671100 05/11/20 08:00 PM
Like this?
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
