Topics49,851
Posts837,443
Posts: 63 |
Since the announcement last Saturday, my factory fitted leather passenger sun visor has taken to drooping from its regular erect position to a sad shadow of its former self.
Is this psychological or age related (Bertie is only six)?
Anybody suggest how to fix?
S3 Roadster Brooklands LE 3/50.
Posts: 2,583 |
Find a diamond shape blue pill and put it into any accessible opening. Should do the trick. If not try inserting a cocktail stick into the hinge bit. Mine droop when going over a cattle grid!
Posts: 27,810 Likes: 749
Posts: 27,810 Likes: 749 |
It is a feature Sir, they all do that.
Posts: 7,553 Likes: 88
Posts: 7,553 Likes: 88 |
Sun visors? Sun Visors? Extra weight and they destroy the aerodynamics!  Bud 4/4 - Stanley
Bud 4/4 "Stanley"
Posts: 2,583 |
Sun visors? Sun Visors? Extra weight and they destroy the aerodynamics!  Bud 4/4 - Stanley They make great wind-deflectors and for winter use are useful when driving into a low sun on those bright winter afternoons. Much worth the extra weight.
Posts: 63 |
Yes, I have noticed the droop increases when accompanied by the rev hang feature.
I must try and find out what the droop feature cost as a factory extra. Presumably it was too expensive to have the drivers side droop feature as well although perhaps Morgan will retro-droop for a couple of £K?
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Droop... really! After almost 7 years and 44k miles mine remain as perky as ever!!
Agree 100% with Phil!
Maybe you need to keep the vibration high to stop the droop. Minimum 4k rpm?
Posts: 8,672 Likes: 489
Posts: 8,672 Likes: 489 |
Anybody suggest how to fix? Unbolt the end fittings from the 'screen, pull out the ends and carefully squish the sort of tube part in the visor, refit & Robert's your uncle
Posts: 63 |
‘Carefully squish’.
Hmmm, I will dig out my Squish o’Matic and hook it up to my Carefullometer then.
Many thanks.
