9 members (PaulJ, Mogdavid, hugo, mph, David Preston, DCH, Willowgreen320, KennethM, Steve +8),
286
Posts837,972
Posts: 13 |
I have a December 1973 (constructed, first registered January 1974) +8, which I bought Easter 1975. I am near completing a 3-year restoration, in the course of which I have replaced the fuse box due to corrosion of the original. Amazingly, I have been able to buy a fuse box that is exactly the same as the original - Lucas 7FJ, which takes 4 glass fuses. There is also an in-line fuse in the brown wire which exclusively feeds the hazard lights.
Can anyone please tell me what value the four fuses in the fuse box should be? I can obviously guess, or put 3/16" bolt in place of the fuses (!!), but I'd rather put in the correct factory values, if possible.
Many thanks in anticipation of someone knowing the answer...
Francis
Posts: 5,594 Likes: 612
Posts: 5,594 Likes: 612 |
Mine ('75 4/4) are all 17 amp ..... not sure how original that is after 45 years
Posts: 13 |
Thanks - but originality is the problem I have! I know the hazard in-line fuse is original, as I didn't even know it existed until a few weeks ago. One of the 4 is 17 amp and looks original, but the others do not and are different values. Though I have no recollection of doing so, at least one is certainly not original... Many years ago, I appear to have drilled out the endcaps and soldered in a new internal fuse wire!
Francis
Posts: 28,909 Likes: 354
Posts: 28,909 Likes: 354 |
If that fuse box is fed from the other side of the car, at the starter relay/solenoid, do put a fuse or circuit breaker in line just after the relay. I did this on my 4/4 after finding that feed is unprotected. ![[Linked Image]](https://www.tm-img.com/images/2017/07/27/FuseMain.jpg)
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
25 amp glass fuses
Four I think (without checking)
Plus 2 spare, stored on their ends
Arwyn
Posts: 8,695 Likes: 415
Posts: 8,695 Likes: 415 |
Any help?  ![[Linked Image]](https://i.imgur.com/WrrEw1P.jpg)
If nothing else, it should improve the flavour of the cheese, Richard!
Posts: 6,675 Likes: 441
Posts: 6,675 Likes: 441 |
If that fuse box is fed from the other side of the car, at the starter relay/solenoid, do put a fuse or circuit breaker in line just after the relay. I did this on my 4/4 after finding that feed is unprotected. What amp fuse do you use in that Graham?
Good question Phil. It actually contains a flat blade fuse, somewhere in the region of 30A if I remember correctly. It was 8 or 9 years ago that I did that mod after a bit of an issue with wiring. Had to replace the high current feed and a number of wires behind the dash.
Good question Phil. It actually contains a flat blade fuse, somewhere in the region of 30A if I remember correctly. It was 8 or 9 years ago that I did that mod after a bit of an issue with wiring. Had to replace the high current feed and a number of wires behind the dash. Cheers
