1 members (+8Rich), 358 guests, and 36 robots.
+8Rich 95
John V6 49
Posts837,992
rockabilly john
#671192 06/11/20 10:29 AM
I have a December 1973 (constructed, first registered January 1974) +8, which I bought Easter 1975. I am near completing a 3-year restoration, in the course of which I have replaced the fuse box due to corrosion of the original. Amazingly, I have been able to buy a fuse box that is exactly the same as the original - Lucas 7FJ, which takes 4 glass fuses. There is also an in-line fuse in the brown wire which exclusively feeds the hazard lights.
Can anyone please tell me what value the four fuses in the fuse box should be? I can obviously guess, or put 3/16" bolt in place of the fuses (!!), but I'd rather put in the correct factory values, if possible.
Many thanks in anticipation of someone knowing the answer...
Francis
FrancisG #671194 06/11/20 10:36 AM
Mine ('75 4/4) are all 17 amp ..... not sure how original that is after 45 years
FrancisG #671199 06/11/20 11:11 AM
Thanks - but originality is the problem I have! I know the hazard in-line fuse is original, as I didn't even know it existed until a few weeks ago. One of the 4 is 17 amp and looks original, but the others do not and are different values. Though I have no recollection of doing so, at least one is certainly not original... Many years ago, I appear to have drilled out the endcaps and soldered in a new internal fuse wire!
Francis
FrancisG #671206 06/11/20 11:34 AM
If that fuse box is fed from the other side of the car, at the starter relay/solenoid, do put a fuse or circuit breaker in line just after the relay.
I did this on my 4/4 after finding that feed is unprotected.
FrancisG #671208 06/11/20 11:36 AM
25 amp glass fuses
Four I think (without checking)
Plus 2 spare, stored on their ends
Arwyn
FrancisG #671243 06/11/20 01:06 PM
Any help? innocent
If nothing else, it should improve the flavour of the cheese, Richard!
TBM Offline
What amp fuse do you use in that Graham?
TBM #671254 06/11/20 01:33 PM
Good question Phil. It actually contains a flat blade fuse, somewhere in the region of 30A if I remember correctly. It was 8 or 9 years ago that I did that mod after a bit of an issue with wiring.
Had to replace the high current feed and a number of wires behind the dash.
TBM Offline
Cheers
