6 members (Gordon D, Mikemog6, Ncik P, Doug J, Ian Wegg, John Winn), 137 guests, and 63 robots.
+8Rich 76
Topics49,860
Posts837,523
Jonny72
#672900 15/11/20 08:46 PM
TimB Offline OP
There are a couple posts on the forum about the HiSpec billet 4 pod brakes. I installed them today on my 1984 Morgan 4/4. However, I ran into issues getting the rear brake pads in. The pads are 98mm wide and 60mm high (15,4mm thick) - Unfortunately, the rear pads touch the stub-axle which means I cannot slide in the pin that secures the pads in the caliper. Two pictures below - some more details on my blog FixingC6622
The pads I have are Ferodo FDB813
Has anybody ran across this issues before?
I can think for two possible solutions:
a) getting brake pads that are just 58mm high (I tried a search engine - without success)
b) filing away a bit of material from the stub-axle (maybe not the best idea as this is the area where the bolts that secure the calipers to the stub axle are located)
Thanks and Regards
Tim
TBM Offline
Yep had the same problem on mine - I don't think its the stub axle that it fouls on, I think it's the brake caliper mounting plate.
I went for a very low tech approx and trimmed a smidge of the corners of the inner pad. Done about 3000 miles will no ill effects....
When I need to replace the pads, I'll probably remove the caliper and trim down the mounting plate.I think a chamfer should do the trick..
TimB Offline OP
If I understand this correct you would suggest to file away the area I (roughly) marked in red here ?
The stub axle has approx 12mm material at this point.... I would need to take away ~2 mill..
TBM Offline
I notice on your journal you are going to talk to Tim Eyres - I'd be interested in their solution.
You have to file a bit of the caliper bracket away to make them fit
You should have been told this or it should have been with the fitting instructions
Simon @ Sifab.co.uk
Sifabtemporary@gmail.com
TBM Offline
I'm pretty sure you could remove 2mm from there without any structural impact. Would need to be the full width - more of a 'notch', although be very difficult to do neatly in situ.
TimB Offline OP
Yes - I already wrote him an email. It is already good to know that you (and maybe others) also ran into the same issue. I wish David Welling's excellent book on maintaining a Modern Traditional Morgan would cover a section on modern upgrades for earlier Morgan's as well... Looks like we need to write this... wink
TBM Offline
Thanks for that Simon - I got mine from Mulfab via BerryBrook, and there was no mention in the Mulfab instructions unfortunately.
TimB Offline OP
Thank you Simon. I only have the HiSpec instructions. They don't say anything about a Morgan smile
Will use the file then. I also installed your new alloy radiator. Looks really great smile
Regards
Tim
TBM Offline
Interestingly:
HiSpec 4 pots from Mulfab - £435 + VAT = £522
HiSpec 4 pots from Mulfab but supplied via BerryBrook - £431.99 incl VAT
