10 members (Paul F, RichardV6, dogmog, MartinB60, DJ66, CooperMan, Alistair, MJF, OZ 4/4, chanteclair), 250 guests, and 8 robots.
John V6 69
DaveW 67
+8Rich 66
9,208 Registered Users
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
M3W - Anyone know this car?
by Biggle - 22/07/25 01:40 PM
Supermax sprocket
Topics48,343
Posts813,021
RedThree
Page 28 of 32 1 2 26 27 28 29 30 31 32
great idea.... stephen, you and I ship our M3W's to England.... meet Phil... and a whole host of folks.... I would enjoy seeing the parts of scotland red3 is at again...
Dang... the lottery ticket only had one number
Rodger
2004 Plus 8 (wife's)
A nice dream but alas not in my future. The closest i will get is shipping a Centa to England. Now to find a spare Centa to ship there so the downtime will not be long when I do the changeover.
Thanks Phil.
How would you suggest cutting that hole for your Centa conversion in SITU? Die Grinder? That would save shipping the bellhousing to you to do the conversion.
I have done the job by drilling four 20mm holes at the corners and then cutting the straight sides with a jigsaw but that was with the bell housing removed and sawing from the inside. from the outside a small wheel on an angle grinder will do the trick. There is plenty of clearance for the blade on the inside but you could check to be sure by measuring through one of the corner holes. If you only want to get in for greasing then why not use a large hole saw? you should be able to see enough through a hole about 60mm in dia.
Thanks for the suggestions Phil.
I was surprised how easy the bell housing is to cut, mine was off the engine. This was all done from the outside, used a 20mm hole saw in the 4 corners and then a jig saw with a long blade run along the edge of the reinforcing webs and then across the 2 ends.
2021 M3W
2013 M3W - Sold
1971 4/4 2 Seater
1934 Sports
Quote
I have an exchange unit here so, you tell me when your engine is coming out - I post the parcel to you, 2 day service - you remove the centa from the parcel, put your old one in it and return to me straight away. I will be short of my unit for a week and you don't have to delay at all. No problems!
That is great news Phil, thanks for the info.
O
O
Have done as you suggested Phil and cut a hole with a 60mm hole saw and have ordered some silicon grease.
Access doesn't look too bad to get some grease in there with a heavy duty syringe or a grease gun with a smallish tube.
I put my endoscope camera in there and the rollers look to be in good condition at 3k miles, still planning to get your mods done a sometime though!
Good job Obie. Did you put a centering plug on the pilot drill of the holesaw so the bigger hole cutter would not wobble around?
O
O
Just the standard arbor and pilot drill that came in the holesaw kit Stephen
