7 members (MartinB60, Morganmike, DMC1904, DJC, Graham, G4FUJ, John V6, nick w), 303 guests, and 44 robots.
+8Rich 64
Adam12 62
John V6 59
9,215 Registered Users
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,364
Posts813,337
Members9,215
Page 3 of 3 1 2 3
This is a possibility for the towed away MOG. https://monimoto.com/shop/
LoJack might make something for motorcycles too.
Me too. My 2012 arrived in Oct. that year. Spare key hanging on garage cupboard since then never used. Just ran out to the garage to test. No problem. Started immediately.
Tom S
Originally Posted by planenut
If all this fails you can always remove the immobiliser from the system by making and fitting an immobiliser jumper plug, as detailed on page 66 of the M3W parts list Ver 5.2 item C-47 on the RH side. You will also need an AMP Multilock 070 12 way male plug and pin set. Morgan could supply these at one time but don't seem to be able to now. I got my plug from www.simtekuk.co.uk and they were very helpful. With the jumper fitted the immobiliser is out of the system, handy for diagnosis as well as a small, light item to carry in your spares bag that may just come in useful one day?
Just been looking back at this as and it seems I got the connectors sex wrong, it should be an AMP Multilock 070 12 way FEMAIL plug and pin set (CON-127). Apologies to anyone who may have got the wrong half. The next Alternative Parts List will be amended.
Keys, how does one get a key replaced that will fit the lock and work properly? Is there a manufacturing code where a key could be sent from the factory replacing a lost or damaged key?
It is a Peugeot lock barrel, so I assume it is also a Peugeot key and, as there is no chip in it, a standard key cut from a blank should be fine from a hardware store.
Looks like i need to go to a better locksmith. Three tries at the hardware store already.
What doesn't work with the replacement key Lightspeed? Will it not fit in the barrel, not allow it to unlock the steering lock, or not allow ignition? I only ask as there was a problem with someone on this forum who replaced the barrel but couldn't get the steering lock to work correctly, fine with ignition. Just wondering if there is a matched chip in the tip of the key, as there is on most modern keys?
Jep Offline
I went to the local locksmith who cut me a new key from a blank and it worked just fine.
This was after I slid down on the seat with the key in the ignition lock hitting it with my knee and
almost breaking it in two pieces.
Jep
It fits into the barrel just fine and it appears to be the correct length but they seem to have trouble cutting the key because of that bloody big plastic handle on the end. I have been tempted to removed that plastic but I don’t know how far up into the plastic the metal goes. It boils down to the accuracy of cutting the valleys and ridges to engage the tumbler pins.
Page 3 of 3 1 2 3
