7 members (riri, vincentvg, RubyMog95, Moggo, John Winn, Hamwich, Jock), 194 guests, and 28 robots.
+8Rich 91
John V6 49
Posts837,976
#67453 01/09/11 11:16 AM
Sukram Offline OP
Hello,
i have all times problems to get the grease in the nipple banghead, witch gun you are using.
With my I need 3 hands that the grease go not on the side
Don't Worry, Be Happy
Morgan 4/4 1985 2,0 Zetec
BMW R1200 GS
Triumph TR140
Sukram #67455 01/09/11 12:17 PM
Hi Sukrum, I have a Draper, with which I also have problems getting on and off the nipple. If it gets stuck on, releasing the pressure wheel/ bleeder thingy may help.
I am told that Wanner are the grease guns of the cognoscenti.
Brian
Brian V #67459 01/09/11 03:23 PM
I use one very similar to this:
You can operate the gun one-handed and apply the nozzle on the flexible hose to the nipple with the other hand.
1972 4/4 2 Seater
tmg513 #67463 01/09/11 04:06 PM
I inherited a Wanner, made the 60's I think, but I'd already inherited an unbranded gun from my uncle who used it on his 100E, and I prefer this to the Wanner. I must polish the Wanner up sometime...........
So I'm a two gun greaser. laugh2
DaveW #67480 01/09/11 05:53 PM
I use pistol type with rigid tube and 4 jaw connector making it a one handed job, all the grease nipples on my 4/4 sport are pointing in the same direction so with the steering on full left lock all 4 are accessible without the need for a jack
tmg513 #67528 02/09/11 06:53 AM
Sukram Offline OP
ok i will buy a One-Hand Gun
BMW R1200 GS
Triumph TR140
Easter #67529 02/09/11 06:57 AM
Green & Grown Up
Green & Grown Up
I also use a Rigid Swivel Tube 3 Jaw Tecalemit (Plymouth England)with Lever Grip, which also has a handy Pressure Release Screw, which I have had for 'donkeys years oldgit '
I find that with it having the long fixed swivel tube the overrider brackets can still get in the way buy have just purchased a trolley jack so hopefully the extra height will solve that problem idea .
With the car Jacked Up it will reach the Upper Nipples Straight On over the wheel top.
Easter is right in that the Nipples need to be turned to allow a perfect 'Straight Coupling' with whatever angle you are working from thumbs .
Any slight 'Off Angle' and the Grease will easily escape nono .
Also the Back Pressure from the Upper Nipples make them hard to fill with my weakening grip.
Frank 4x4 #67557 02/09/11 12:30 PM
I have 2..........
a clarke manual and a clarke pneumatic.
pneumatic is the way to go.......
and thats not meant to invite lewdish comments!!!!
sospan #67558 02/09/11 12:30 PM
But then... why not? hehe!
