8 members (Montegue, TalkMorgan, tezzer, Graham, G4FUJ, RichardV6, CooperMan, JohnHarris, Haggispeed),
349
Posts837,983
Posts: 413 |
Hello, i have all times problems to get the grease in the nipple  , witch gun you are using. With my I need 3 hands that the grease go not on the side
Don't Worry, Be Happy Morgan 4/4 1985 2,0 Zetec BMW R1200 GS Triumph TR140
Posts: 478 |
Hi Sukrum, I have a Draper, with which I also have problems getting on and off the nipple. If it gets stuck on, releasing the pressure wheel/ bleeder thingy may help.
I am told that Wanner are the grease guns of the cognoscenti.
Brian
Posts: 2,515 Likes: 1
Posts: 2,515 Likes: 1 |
I use one very similar to this: You can operate the gun one-handed and apply the nozzle on the flexible hose to the nipple with the other hand.
1972 4/4 2 Seater
Posts: 22,370 Likes: 354
Posts: 22,370 Likes: 354 |
I inherited a Wanner, made the 60's I think, but I'd already inherited an unbranded gun from my uncle who used it on his 100E, and I prefer this to the Wanner. I must polish the Wanner up sometime........... So I'm a two gun greaser.
Posts: 1,558 Likes: 5
Posts: 1,558 Likes: 5 |
I use pistol type with rigid tube and 4 jaw connector making it a one handed job, all the grease nipples on my 4/4 sport are pointing in the same direction so with the steering on full left lock all 4 are accessible without the need for a jack
Posts: 413 |
I use one very similar to this: You can operate the gun one-handed and apply the nozzle on the flexible hose to the nipple with the other hand. ok i will buy a One-Hand Gun
Posts: 3,727 |
I also use a Rigid Swivel Tube 3 Jaw Tecalemit (Plymouth England)with Lever Grip, which also has a handy Pressure Release Screw, which I have had for 'donkeys years  ' I find that with it having the long fixed swivel tube the overrider brackets can still get in the way buy have just purchased a trolley jack so hopefully the extra height will solve that problem  . With the car Jacked Up it will reach the Upper Nipples Straight On over the wheel top. Easter is right in that the Nipples need to be turned to allow a perfect 'Straight Coupling' with whatever angle you are working from  . Any slight 'Off Angle' and the Grease will easily escape  . Also the Back Pressure from the Upper Nipples make them hard to fill with my weakening grip.
Posts: 9,552 Likes: 134
Posts: 9,552 Likes: 134 |
I have 2.......... a clarke manual and a clarke pneumatic. pneumatic is the way to go....... and thats not meant to invite lewdish comments!!!!
But then... why not? hehe!
