Posts837,276
Posts: 12,255 Likes: 317
Posts: 12,255 Likes: 317 |
Update: 4 December 20
I haven't used Tarka for 8 or 9 days. When I parked the battery voltage was 12.6v. Today it was 12.3v So, I'm beginning to believe that the battery I had was faulty: this on holds its charge. When it is at 12v I'll either drive the car or put the charger on.
Is there a reason why you don't simply leave the car hooked up to the battery conditioner when you put it in the garage? Mine's on all the time when I'm not using it.
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
Posts: 27,802 Likes: 749
Posts: 27,802 Likes: 749 |
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
I have only done 1300 miles over the last year (MOT mileages). Covid put the brakes on over the last 9 months but the Ctek has been used plus running the engine at 2 week intervals. No starting problems even with the “ageing” Odyssey battery. I need to put some miles in to keep the brakes/suspension moving.
Fair enough. I have a connector plumbed in permanently so it's just a question of plugging in the charger when I get out of the car, takes just a few seconds.
Posts: 8,663 Likes: 489
Posts: 8,663 Likes: 489 |
Peter your post prompted me to check mine The Roadster is the late model with BCU, immobiliser & other potential electrickery, has not been on charge for a couple of weeks & shows 12.41v The over 70yr old F Super shows 12.73v perhaps a credit to simple wiring
Posts: 5,586 Likes: 603
Posts: 5,586 Likes: 603 |
No doubt battery experts may disagree but I work on battery voltages (battery rested after either charge or significant discharge)
12.8 ish .... fully charged
12.4 ish ..... half charge
12.0 for any length of time .... walking the line of goosing your battery.
Posts: 28,888 Likes: 350
Posts: 28,888 Likes: 350 |
And the next post: The secret of good comedy - timing!
Posts: 8,657 Likes: 407
Posts: 8,657 Likes: 407 |
Sorry Peter that's a bad policy. Leaving a lead/acid battery discharged to almost any degree for a length of time kick-starts the downward spiral of battery degredation through sulphation of the plates. FWIW Lithium Ion batteries on the other hand have best storage life when left in a cool environment charged at 40% of full capacity. I wouldn't be too complacent about your new battery either. Fair to assume it still has its advertised capacity so it's already lost around 20 amp hours in 9 days, well above typical natural discharge. When the capacity has dropped to say half, the same 20 amp hours discharge will have a far greater effect on remaining charge. Sorry to be so negative, just telling how it is.
The battery is now on charge....!!
