Morgan Aero 8
1 members (+8Rich), 313 guests, and 86 robots.
+8Rich 77
Topics49,870
Posts837,667
Rudolf
Page 4 of 6 1 2 3 4 5 6
drewg Offline OP
Originally Posted by Alistair
https://www.aero-racing.co.uk/partsbooks/supersports/driveshafts.diff.prop_shafts.htm
DRIVE SHAFTS, DIFF & PROP SHAFTS (HOVER OVER LABELS TO VIEW PART & NUMBERS)
#. PART NUMBER PART NAME
1. MRA20703 PROPSHAFT MAN
2. MRA20704 PROPSHAFT AUTO
Thanks, eventually found the same numbers but will let the dealer determine if it's MRA 20704 (Which is for the Supersport but may be the same for the S4 which also uses the 4.8 engine and Auto box) otherwise picked upon the S2 - 2016 pdf T12046 (Though I'm not convinced this is right as could be for the 4.4 engine) confused. Hopefully the factory will know though been 2 days now waiting to hear tumbleweed
AnDrew G
2003 Aero S1 - past
2009 Aeromax - past
2012 +4 Supersport - past
2008 Aero S4 -past
Will be getting under before the next drive to check mine.
Just a thought could anyone answer if a manual or auto would put more stress through the propshaft? I wonder if the torque converter absorbs some of the stress when driven hard?
David
Aero S4
Ray Offline
It doesn't look a complicated bit of kit for any propshaft engineer to make a copy of.
You don't need to get an OEM shaft. There are some excellent prop shaft manufacturers and I have attached a link to one of the best IMHO.
Used to supply them when I worked for Dana Spicer many years ago.
Bailey Morris Propshafts
Give them a call and explain your predicament and they will advise the best course of action.
BTW, if you can get your shaft to Bailey Morris they will be able to determine the probable cause of the failure.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
drewg Offline OP
Thanks Bob,
I will try them tomorrow to see if they can make one to factory spec without my old 1. My reasoning which I've shared with Dean who knows a similar company up north is I gues the car would be taking up a ramp to have the rear suspension dropped to remove the old propshaft so don't want to be paying expensive Morgan labour rates to reassemble suspension to remove car from ramp to later once new propshaft arrives to reverse the process. So I see most cost effective solution is a new propshaft to be installed straight after removal of the split 1 (I'm not mechanically minded...but can design and build houses laugh2).
Cheers
AnDrew G
2003 Aero S1 - past
2009 Aeromax - past
2008 Aero S4 -past
Originally Posted by drewg
Just noticed a receipt from the factory back in 2016 which noted O/S Lower Ball joint movement (which they replaced 2 weeks later) and"Prop Coupling has Minor Split" (not repaired clearly...maybe it was smaller than now and not seen as important?). Now I wondering if this is the source of the vibration confused2
pale
Difficult to say without knowing the frequency of the vibration, but I would have thought it fairly likely. Wont be the split itself but the prop shaft is now likely not to be straight. I can vouch from boat experience that when a prop shaft bends it vibrates the structure quite badly. And that vibration varies with road speed not engine speed.
I suggest you try going down a nice flat bit of road at the same speed but in different gears. If then the vibration stays the same you can be sure that its caused by something in the drive train after the gearbox. Go a little bit faster and the vibe should speed up. The sort of vibe you get from wheel balance iis a resonance vibe occurring at a speed band. The vibe from that shaft should occurr at all speeds.
Anyway, get it replaced. If that shaft fails in use it will flair about and cut through the structure and you with ease
drewg Offline OP
waiting MMC have evntually emailed today to say don't have stock of a replacement propshaft for my Aero and the supplier is shut for xmas till new year tumbleweed Very frustrating not being able to use my new toy though having to move it 36 miles tomorrow as moving house....will be taking it very easy. pale
AnDrew G
2003 Aero S1 - past
2009 Aeromax - past
2008 Aero S4 -past
Andrew,
Please be very, very careful.
If the MMC supplier of the new shaft is the same supplier as the old shaft , then I would want to know why the old shaft failed.
Has the supplier made changes, was it just bad luck in your case, is the supplier using inferior quality tubing or maybe it just had a knock.
In my prop shaft days, the OEM would want a full investigation into a failure like that. Root cause analysis etc.sherlock
So many things to worry about.
Bob
2009 Black Roadster
Really sorry to read that, good luck with the move.
Frustrating but take great care when moving that car....
