Posts837,997
Posts: 203 Likes: 8
Posts: 203 Likes: 8 |
Having serviced the car without issue I thought I’d smarten up the rear brakes whilst I have the case up on stands, oh dear...
I’ve got new hoses OK, and wheel cylinders, but am struggling with the shoes - I bought them here from a German based online retailer, they say there for my car and the part number checks out with others I’ve found on here, but the hole in the top of the leading shoe for the auto-adjuster is too large and too far away, and instead of a hole for the lower part of the adjust there is a post - has anyone else had this problem or have any advice with regard to part numbers?
Mike H Bourgogne Franche Comté
Posts: 27,836 Likes: 763
Posts: 27,836 Likes: 763 |
Mike GoMog has advice & if PM me your email I can send you the official parts book. I have never done work on the rears but others on here will have. Brakes
Posts: 37,479 Likes: 988
Posts: 37,479 Likes: 988 |
Hi Mike,
The part number for the rears are Delphi/Lockheed LS1311, I fitted these to my car around three years ago when I changed the wheel cylinders Caparo/AP CW15953.
I followed the guide that John provided the link for you from Gomog it helped a lot.
Posts: 203 Likes: 8
Rich
Thanks - I got the cylinders from Brown & Gammons and they’re fine (brakes international were out of stock), I used one of AutoDoc’s many companies for the shoes - just trying to sort a refund/ exchange with them now.
Posts: 203 Likes: 8
Thanks, I did consult Gomog before starting, I think I just made the mistake of taking AutoDoc’s recommendation at face value, and looked at far too many references and part numbers here and elsewhere!
Posts: 1,616 Likes: 143
Posts: 1,616 Likes: 143 |
What year/model is the car?
Arwyn
Posts: 203 Likes: 8
Arwyn Arwyn 2000 +8 3.9 hotwire
Posts: 513 Likes: 2
Posts: 513 Likes: 2 |
I had exactly the same issue. Correct part numbers and from a reputable source. I sent them back for a full refund after trying to fit them.... they didn't fit properly.
The supplier had not heard of any issues but I took photos and they are clearly different.
I'm still running on the old shoes until I am brave enough to try again.
