0 members (),
229
71
Topics49,870
Posts837,668
Posts: 62 Likes: 1
Posts: 62 Likes: 1 |
Hi. I am considering buying a 1970s four speed plus eight just pondering on the pros and cons between these and slightly more modern ones. Any views gratefully received. Thanks Steve.
Posts: 28,904 Likes: 352
Posts: 28,904 Likes: 352 |
The slightly later 5 speed will give you a more relaxed cruising speed, without too much extra car width... My model of choice in +8...
Cheers,
Posts: 22,366 Likes: 354
Posts: 22,366 Likes: 354 |
The trouble is........ Those narrow early Plus8's are the best looking by far.
Yeah, I know. I think the early 5 speeder is only a couple of inches wider though... Need to confirm that.
A 'cheap' narrow Plus 8 "needing work" might tempt me away from a Lotus Elise.......................
Posts: 37,435 Likes: 978
Posts: 37,435 Likes: 978 |
Hi Steve Having run a 93 +8 with wide body with the 5 speed box it's a relaxed drive. The early narrow body model is lovely but they have the Moss 4 speed box which can be an expensive rebuild, if that seems good go for it, because you'll enjoy it so much. Enjoy your miles. Richard
Posts: 62 Likes: 1
I was wondering about the lower bhp for the rover four speed box ones. From what I can understand they are 143bhp but slightly higher geared so perhaps acceleration is preserved at the expense of fuel consumption? Steve.
Posts: 27,816 Likes: 749
Posts: 27,816 Likes: 749 |
I've driven a late model ('75/'76 - P reg) Rover 4-speed +8 and very briefly a Moss box car from '69. I've not driven the Rover 5-speed in a +8, but a number of years ago in discusion with Ben Duncan and others 5th is a taller ratio than 4th in the 4 cog - an 'overdrive' gear. The Moss gearbox was replaced in the early '70s ('72 rings a bell) by the Rover...
As John says, there's lots of info. out there. Not at home this week to look up my 'library'. Also have a look at Hermen Pol's web site.
Cheers,
Posts: 62 Likes: 1
Thanks everybody for your info. Just been to look at and drive the car I was thinking of 1974 plus 8 in pretty good, fairly original condition. The gearbox felt quite nice to use the clutch and the steering weren’t too heavy, which were things that were slightly worrying me although the steering being the early box type was a bit wander hopefully it could be changed for a gemmer one? The upshot is, I am looking forward to picking it up next week. Thanks again Steve.
