8 members (IcePack, RichardV6, Mogdavid, Bishmog, Paul F, Grumpy2, Rog G, TBM),
308
40
Topics48,364
Posts813,343
Members9,215
Posts: 3,581 Likes: 85
Posts: 3,581 Likes: 85 |
Posts: 2,384 Likes: 56
Posts: 2,384 Likes: 56 |
Ian. I think you probably have the alloy plate which looks like a thermostat gasket with an O ring bonded to it. Em
Posts: 62 |
Many thanks Ian!!!!!!!!!!!!!!!!!!!
I have exactly the same setup! Including dellortos, year and colour!!! Now to source a manifold!!
Posts: 2,515 |
It might be worth checking the state of your engine mount rubbers. When I replaced mine it raised the engine about half an inch which would help the front trumpet to clear the wing.
1972 4/4 2 Seater
Posts: 28,428 Likes: 180
Posts: 28,428 Likes: 180 |
An ex-works measuring stick Ian
Sold L44FOR 4/4 Giallo Fly '09 Gen2 MINI Cooper ragtop '90 LR 90 SW
You noticed Graham! My metal rule has gone walkabout but I found that in a kitchen drawer, it's probably a valuable museum piece now.
Posts: 26,760 Likes: 425
Posts: 26,760 Likes: 425 |
The hose by the ruler looks bit tired
Posts: 4,612 Likes: 194
Posts: 4,612 Likes: 194 |
Thanks for the Dellorto info aerotaff, Webers on a Twink bring back a lot of memories...
Luddite. Your absolutely spot on regarding the Thackery washers or Jackanory washers as we used to call them the gap from memory was about 25 to 30 thou with a bit of movement, spent too many hours in my yoof fitting webbers very badly. I think Ians carbs could do with 4 new o ring plates they look overly compressed there is certainly an oil or petrol leak near or under those carbs. Em
Nice to know some elements of my memory may still be in tact Aerotaff. I do have an original 60`s Lotus Elan manual somewhere, but it is simpler to search the web than search the house and garage.. https://lotuselan.net/forums/viewtopic.php?f=40&t=30129&start=
