I felt the same way you do now.
On our Plus 4, we also had the armture board redesigned to our liking.
The dash was manufactured by
MK Holztechnik and the conversion was done by the Morgan dealer in Austria. On this occasion we also had the dials of the instruments changed from black to ivory.
Two notes:
The space above the steering column is very tight (for the two large instruments). On our Plus 4, the wooden frame had to be worked out a bit.
Due to my height (190 cm), the upper dials of the speedometer and tachometer are covered by the steering wheel. In the meantime, however, I have gotten used to it.
I would do the conversion exactly the same way again.
Good luck!
![[Linked Image]](https://tm-img.com/images/2018/03/22/dash_1.jpg)
![[Linked Image]](https://tm-img.com/images/2018/03/22/dash_2.jpg)
![[Linked Image]](https://tm-img.com/images/2018/03/22/dash_3.jpg)
![[Linked Image]](https://tm-img.com/images/2018/03/22/dash_4.jpg)
