8 members (Graham, G4FUJ, John07, lord-richfield, Trim, nick w, ADMOG, Topline123, mph), 294 guests, and 40 robots.
+8Rich 65
Adam12 62
John V6 59
9,215 Registered Users
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Pur Sang Type 35
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,364
Posts813,342
Members9,215
Page 1 of 4 1 2 3 4
#679162 21/12/20 03:17 PM
Say gents, does this look like I can move the pedals one more slot forward? Or will I have to drill holes? The pic of bolts under looks like it's all the way forward? Are there two bolts or four?
end user
looks like you are as far forward as it goes
Rodger
2004 Plus 8 (wife's)
The later pedal box that you have, the original 2012 item had "M3W" laser cut into the pedals and a recall against it for failure, is attached as far forward as the mounting holes allow. Have a check of how much clearance there is between the front of the master cylinders and the chassis tube, you may have a replacement later chassis as well that allows more forward movement. If there is room you will need to drill extra mounting holes in the floor. Just seen your other thread about bolt in A frame, so you don't have a later chassis, in which case the pedal box is as far forward as it goes.
Okay, thanks, I will check and see. I think I have a more dire problem. There is fluid leaking out of the clutch damper at the back of pedal. Circle below. I think this fluid is corrosive, right? Hence the rust? Is there a way I can fix this just by tightening, or do I have to remove and replace o ring? thoughts?
end user
if it is brake fluid is will damage paint. However, it will not cause rust
Rodger
That's the clutch master cylinder, same as the later 4 wheel Trads, I've tried in the past but couldn't get seals, so best to replace anyway
You have some pretty significant surface rust on that floorpan & I also suspect where it contacts the lower edge of the chassis frame, it really needs taking off the trike and treating properly
yeah the dealer missed this apparently. it's my problem now.
end user
working on the rust problem. The Morgan shop here in Detroit is pricing the cylinder for me. here is a morning's work sealing with rustoleum. If I don't get the leak solved, I'll have to do it again
end user
I would have been tempted to pull the bottom plate out and dip it in a rust dissolver solution and then paint. That rust was pretty extensive and a coat of rustoleum will not keep it at bay for long
Rodger
The black baseplate looks much better than the original photo, how did you apply the rustoleum?
I have been doing some tests with rustoleum and not been too impressed , maybe I am using it wrong !
Page 1 of 4 1 2 3 4
