7 members (Morganmike, piquet, Ian Wegg, Robbie, linklaw, Clipper, Alistair), 337 guests, and 44 robots.
+8Rich 92
Topics49,837
Posts837,291
Page 229 of 264 1 2 227 228 229 230 231 263 264
Last race before noel.
A quick run round Aberdeen on New Years Day.
Calum, do you spend much time driving close to the shore where the moisture in the air is higher?
Nice New Year photo with the rainbow giving us all hope.
Will certainly need to wash off the salt spray
Rodger
2004 Plus 8 (wife's)
After the fun and games getting the car started with the battery problems, I finally picked her up today and drove her home in lovely sunny weather. Oh, I’ve missed her! And missed driving her...
Then after a check over off to get the MOT done. Again beautiful weather, and as the receptionist told me she had passed, I noticed out the window that the heavens had opened. gloomy
The tester had kindly kept her inside, so I could dress up in the dry, but the trip home was very wet. Rain certainly hurts at 40mph.
She is now dried off and tucked up for the first time in her new garage.
What a great day! happy3
Rob
Bavaria 46, 20% of Hunter Impala. 100% of another Hunter Impala, black 4/4 Competition
I went out for a quick 20 mile loop to test how the new Emerald ECU worked in 38F degree weather. It did just fine, althought when the engine is cold it needs some idle time to warm up enough to run properly. It does NOT run as lean as the MC ECU.
Nice to know that the G56 Emerald ECU runs things so well, that sounds nice and smooth. It may be the future if S&S ECU's become a supply problem. Are you still using the MMC stage 1 exhausts ?
Yes I am. Once I have run this a few hundred miles I might put on the stock mufflers that have had a baffleectomy and see if the ECU senses it. I must say, the Emerald ECU is much easier to get to than the MMC ECU. The MMC ECU is a proper PITA to get to for anything.
got out yesterday for the first time this year. I do admit the oil temp on start up was 35f, but the sun was shining and the ice was clear from the roads. So on with the long johns and a tour through Christiansburg and Blacksburg and back home going about 30 miles. The oil was about 200f when parked.
Rodger
drove in to work this am.... it was 33f and after 14 miles the oil temp got all the way up to 150f...... HOWEVER, the sun is out!
Rodger
