For the restauration of my Morgan 4/4 (from 1984) I ordered a new wiring loom from Autospark. According to their website it is a replica for a 4/4 from 1985 with Ford CVH engine. Looking at the cables for the fusebox on this new loom it is clear that this NOT a direct replica. There are 18 (unknown spade type) male connectors that for the fusebox.
The loom has more similarity to the 1988/1989 diagram found on GoMog - but I believe it lacks a DimDIpModule.
The GoMog pages also document that the factory started to switch to blade fusebox at some point after 1986. I called AutoSpark and Melvyn Rutter - but both cannot help with the fusebox.
If your Morgan 4/4 was built between 1986 and 1991 (Ford CVH engine) and does not have the old Lucas 7FJ 4-way fusebox - it would be great if you could provide a picture (or if known name/partnumber) of the box.
It would also be great to known which fuses need to be used for switch circuit.
Thanks in advance
Tim
