0 members (), 266 guests, and 39 robots.
John V6 69
DaveW 64
+8Rich 62
9,208 Registered Users
by Soleng - 24/07/25 05:32 PM
MulFab and Petrol Tanks
by Rovert - 24/07/25 09:51 AM
Maybe an MX5
by howard - 23/07/25 04:10 PM
Dashboard Turn Signal Light
Ozzy Osbourne
Topics48,347
Posts813,076
aeroed, DJC, James Mc, JimWhin
Hello all!
I have just acquired my dream M3W (2013 Brooklands) and for the life of me I can't figure out how I can get the odometer to display the number of miles on the vehicle. I have an owners manual on order but would appreciate anyone's help if they can point out how to do this in the meantime. I have tried searching the forum, but I didn't see anything that could help. This forum is fantastic and really helped to guide me with the purchase.
Just keep tapping the button in the end of the turn signal stalk and cycle through the display.
did you push the little end button of the turn signal stem? It should cycle through miles, trip miles, time and volts
Rodger
2004 Plus 8 (wife's)
Hi, #33 Brooklands (M3W) owner here, welcome! thumbs
Unless there is something wrong, the mileage is shown in the digital display where you have the clock, all you have to do is to press the button on the turn signal stick (?) until you get it. Not sure what order the info shows up but there you have: clock / total mileage / parcial mileage / voltage
2010 Morgan +4
2014 M3W Brooklands
To be raced
If you press the button on the end of the turn signal stalk with the ignition on, the display in the speedometer should cycle through battery voltage, odometer, trip meter, and time.
A long press can be used to program the clock or zero the trip meter.
2020 M3W
Welcome to TM Socalm3w. Odometer as has already been mentioned. Just for info, when you have Voltage selected, if you press the indicator stalk button with a long press, you will get "ILL" followed by a number, that is the instrument illumination level and can be adjusted with a short press and a long press to set. That also isn't mentioned in any handbook.
and then if you push the red button..........
Rodger
Whatever you do, don't push the red button
Scott
2018 M3W
1995 Porsche 993
Very useful, thanks Planenut!
Fantastic instructions everyone! Thank you so much.
