Topics49,904
Posts838,076
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
I think that is the plug for the temperature gauge, not a pre heater
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
The preheater will i deed get plugged into the mains in the garage. I already have a water proof mount in the gauge panel under the dash. The 1/8” npt threaded hole to the right of the Morso heating element is for my existing engine oil temp sensor. ![[Linked Image]](https://www.tm-img.com/images/2021/01/06/IMG_0357.jpg) ![[Linked Image]](https://www.tm-img.com/images/2021/01/06/IMG_0358.jpg) Pre-heater socket on the left, open and covered photos.
Posts: 2,223 Likes: 183
Posts: 2,223 Likes: 183 |
Wow that's so clean in there you mustn't have dirty roads in WA!!
Wow that's so clean in there you mustn't have dirty roads in WA!! I have a vacuum cleaner.
Posts: 902 |
Do you have a price for the oil tank and associated components? By the way, that looks ace. Well done.
Do you have a price for the oil tank and associated components? By the way, that looks ace. Well done. You would have to discuss that with Morgan Custom. I am the test bed, along with the one he is building for himself. His tank has another feature which is pretty cool but not necessary for the operation of the oil system but it adds cost and that is a viewing port near the top of the tank so he can see the spraying of the oil back into the tank.
Posts: 365 |
I just installed Emil’s oil tank as well. Very solid and well thought out. Oil lines are better positioned and should allow plenty of venting. I was surprised my oil vent line was filled with oil. The sight gauge to check your oil level is
2017 M3W Sport Green
Posts: 131 |
Visited with Emil yesterday to have him install this happy-venting oil tank (black powder coated) and his fuel pressure system upgrade. Combined with his oil cooler, this is a pretty slick setup. Not to mention, it looks OE and probably should have been.
'17 M3W (BRG) '03 Plus 8 35th Anniversary (BRG) '08 Ural Patrol (BRG) '21 Vespa 'Racing 60' (BRG)
