1 members (Bitsobrits), 306 guests, and 84 robots.
+8Rich 84
Topics49,860
Posts837,485
Jonny72
Page 4 of 4 1 2 3 4
MJW Offline
Thanks John, I think I that may now have finnaly got to the bottom of it, looks like you need to fit a subtantial solid cased lip seal, this acts as a solid spacer, which retains the inner bearing race, which in turn does not allow the bearing\shaft to move outwards, and does not distort like my old rubber seals. The bearing retainer on my car does not really flex, it is pretty strong, I have now fitted solid cased seals and it looks a lot better. I got the seals from Technics, look much stronger than the seals I got from a local bearing supplier. Of course cost was a lot more, but I am happy with the end result.
Bob,
You have undersood the basic design correctly. Yes the bearings are tappererd to allow for thrust towards the differential. There is not much load in the outward direction, as the opposite wheel is taking that load. So this small outward load is taken up by the bearing retainer ring, which is bolted to the flange on the axle casing which holds the brakes and shock absorber. The bearing retainer stops the seal from coming out, which in turn stops the bearing inner race from coming out. The inner race is secured solidly to the half shaft so cannot come off. In other words there is more or less no allowance for load in the outward direction, it is simply a retaining device, not a load carying device. Strange but true.
Not sure I'm allowed on this forum, but If i am allowed I can send you an email with a simple drawing or a photo of the device stripped down,. Would this help?
1997 +8 4.6ltr,
MX5 ND 2.0Ltr
Rover Sterling 2.7ltr
Touareg 3.0Ltr
Thanks Martin, Yes that would be a big help.
I'll PM you with my e mail address.
In effect the seal is also acting as a thrust washer so I'll be very interested to see what that looks like in the flesh.
Bob
2009 Black Roadster
1999 4/4 2 litre Zetec
Martin,
Did you get my PMs.
I did get yours.
Bob
2009 Black Roadster
Hi,
Could somebody please tell me how I can identify what axle I have in my 2009 4/4?
I think it's a BTR but I'm not sure.
Its not like the drawings on this thread, it has the oil filler on the front of the axle, not on the rear cover?
I am thinking I may have to pump the old oil out through the filler as I cannot shift the drain plug, its stuck solid.
I have fitted a panhard rod in behind the axle and now cannot get a socket on the drain plug (there's not enough room) and I cannot get enough purchase on the ring spanner to release the plug :-(
2009 4/4 Sport in Red
2022 Harley Davidson FXLRS Low Rider S
1977 Triumph Stag
Originally Posted by Redfate
Hi,
I do know my panhard rod was partly removed to allow access to the plug.
Craig Jezz
Thankfully I managed to undo the drain plug this evening, I had to weld an extention onto my ring spanner to gain enough leverage cowboy
Left it to drain overnight now......I'll worry about refilling it tomorrow cheers
Thanks for the heads up Craig but thankfully I was able to do it with the panhard rod in place.
1977 Triumph Stag
Page 4 of 4 1 2 3 4
