0 members (),
395
74
Topics49,867
Posts837,614
Posts: 13 |
So I was changing the oil and next to the filter i discover a wire hanging down after I changed the oil filter. Everything looks to be in order - nothing exposed - but this thing is hanging. I can push it in to a nut just outside the filter but it doesn’t feel right. And it’s not threaded. Any thoughts? Can’t figure out how to post a photo small enough to share 😩
Posts: 3,857 Likes: 2
Posts: 3,857 Likes: 2 |
Post your question on Facebook on the Thre Wheeler forum, photos are waaaaay more easy.
Posts: 2,242 Likes: 72
Posts: 2,242 Likes: 72 |
The wire could be the oil pressure sensor wire as it is next to the filter. In the photo (this isn't quite like the standard set up as it has a sandwich plate) the pressure switch is the silver and black item at about 4 o'clock in relation to the filter housing, with a wire going to it. If it is disconnected the oil pressure light will not operate correctly. For info there is a section on posting photos in the "Welcome Forum" at the top ![[Linked Image]](https://www.tm-img.com/images/2021/01/18/SPA-oil-kit-adaptor.jpg)
Posts: 491 Likes: 6
Posts: 491 Likes: 6 |
I would think it is the oil pressure switch, i broke mine when changing the filter
2015 +4 and 2000 4\4 1981 Lambretta GP225 1960 Lambretta LI 125
Posts: 488 |
That's why i switched over to using the KN-171B filter listed in Planenuts alternative parts list as it has a nut on the end so removing is easy.
Posts: 13 |
Thanks. That’s definitely it. It looks like everything is hooked up correctly but the whole steep just needs a place to live, and I must have knocked it off while changing the oil filter like Hugo. I think even taping it would work. Hugo?
Posts: 491 Likes: 6
I had to replace the oil pressure switch as the nut had snapped off and the spring had come out
I relocated the oil pressure switch by putting in a grease gun flex line and then mounting the switch to the frame members. It gave more room around the filter and it also allowed for an oil pressure gauge sender to be installed. ![[Linked Image]](https://www.tm-img.com/images/2021/01/18/C075DBE1-5F0F-4A9E-AF50-7B0A2954E2EA.jpg) This was my crude test to see how well it worked with the massive oil pressure sender that came with my gauge. I need to find a smaller sender.
Will the engine start with the oil pressure switch disconnected?
