4 members (BertL, +8Rich, TBM, MartO), 187 guests, and 86 robots.
+8Rich 77
Topics49,870
Posts837,668
Rudolf
Page 3 of 3 1 2 3
This may help, it's the brake, but the principle is the same
John V6 Offline OP
Oliver just be careful especially on the brake as if you move the pedal further in you need more pressure to get the braking effect. If you go out the other way i.e. rotating the rod clockwise the travel gets shorter. I did it on my brake by slackening the nut and whilst pushing the pedal in & out rotating the rod by hand. If you brakes have long travel you may be able to move the brake higher & closer to the clutch. Mine are both aligned and the throttle now sits closer to the brake so I can toe & heel easily. I have the MKII development throttle pedal fitted for now.
Cain has a guide to the set up on his Wolf website.
Guide
O
O
Thank you Jon and John,
I'll have a look at it this weekend, hopping I can squeeze in!
Page 3 of 3 1 2 3
