2 members (JoeSpeetjens, Ian B), 267 guests, and 81 robots.
+8Rich 76
DaveW 52
Topics49,867
Posts837,614
Moggo
#684668 22/01/21 06:53 PM
U
Uzi Offline OP
U
Sorry guys
Being new to the topic
Just bought a 2014 roadster
Any advise what to do for corrosion protection also irt conservation ?
Thanks
Ulf
Ulf
France
Morgan roadster
Welcome Ulf. I think a lot of people use ACF50 light lubricant anti corrosion spray on the wing seams etc , and something heavier on the underbody. I havent used it, but this seems popular https://www.lanoguard.co.uk/product...Y_UVqveCk2gb-WJMWC53-xcNP7EaAv7MEALw_wcB
or of course there's the traditional Waxoyls, also Comma do a wax-oil spray that I have used- As with everything its all easier up in the air. Alternatively, develop an oil leak at 50+kph, should cover everything banghead I know!!
06 Saab 93
And, with your warmer climate, don’t forget to regularly nourish the leather, to prevent drying out and cracking. I use Turtle Wax Luxe leather cleaner and conditioner, which is reasonably priced and smells good.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
U
Uzi Offline OP
U
Thanks
Ill give it a try
I was little surprised about the level of blistering/bubbling up when i was looking for a car
My purchase looks well kept and the ivory body shines as new want to keep it that way incl the undercarriage....
Ulf
France
Morgan roadster
Ulf,
some people say ACF50 affects the seam material & prefer light oil like 3 in 1. Check all the earths as they can corrode & make sure there are no leaks into the indicators.
Earths
U
Uzi Offline OP
U
3 in 1?
Ulf
France
Morgan roadster
Uzi .... this stuff .... nothing fancy.
https://en.m.wikipedia.org/wiki/3-In-One_Oil
U
Uzi Offline OP
U
Thanks
And how would you apply it?
Ulf
France
Morgan roadster
I am in a similar position, I have started on the underside with Bilthamber Dynax UC on the metal work but, have used Dekaphon 9735 on the rear inner wheel arch panels and the underside of the floor boards as it appears designed for the job. I have used ACF 50 on boats before but will use 3 in 1 on the wing beading. Will probably do the top of the floor boards and other less exposed plywood with Deks in due course.
