3 members (IcePack, deano, Tony Quinn), 287 guests, and 71 robots.
+8Rich 77
Topics49,859
Posts837,513
Jonny72
Page 1 of 5 1 2 3 4 5
#685736 29/01/21 09:54 AM
tom+4 Offline OP
hello
i drive a morgan +4 2008 and did not pas belgian mot , because to little ground clearance
,the car is in origional condition with the right spec tires and rims .
in belgim the car has to be 11 cm above the ground and i do not have even got 9 cm .
I already passed mot 6 times whitout any isseu and now i failed because of that isseu
Please help
mvg tom
TBM Offline
The simplest solution might be to get a different set of tyres with a much deeper aspect ratio. That 'might' be enough to give you a couple of centimetres? Otherwise I imagine it's going to be suspension work.
Inflating the tyres to a higher pressure might help.
RJW Offline
I have just changed the tyres on my plus 4 2013 to 65 aspect ratio in lieu of 60 which is standard for the car with 15inch wheels. This gives more ground clearance (about 10mm I think).
Bob.
TBM Offline
A new set of rear springs would probably give you a decent lift at the back, cheap to buy (under £300 plus Brexit tax) - simple but time consuming to fit.
I don't know enough about the front end, but there's bound to be some form of spring change that would give you a lift.
9cm does seem a bit low - just been out to measure mine (albeit a '72 4 seater on new rear springs and big fatty tyres) and I've got almost double that clearance between the bottom of the chassis rail and the floor (17+cm).
Formerly known as Aldermog
My AERO Plus 8 would not pass at all, the silencers and sump plate are all less than 8cm.
It seems that the Belgian MOT people are retrospectively applying modern regulations: all new cars must clear 10cm.
But so far it is not part of the UK MOT.
TBM Offline
My road has a primary School, so is a 20mph zone, with speeds humps all the way along. I don't think I'd get in and out with 8cm!
For comparison Tom, my 2011 plus 4, (38000miles) with 195/60 tyres inflated to 22psi on 15 inch wheels has 9.3cm measured to the bottom of the bell housing.
Last edited by Deejay; 29/01/21 11:16 AM. Reason: deleted question on mot limit as already in op posting
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
My 2011 4/4 has about 7.5 Cm with 175/70 HR15. That is to Wolf's rubbing plate.
TBM Offline
195/60 x 15 tyres have a diameter of 24.21". To get a 2cm raise, you're going to need at least a 2" increase in diameter.
195/70 x 15 tyres are 25.75", 195/75 x 15 are 26.52"
Useful tyre tool as an indicator - Tyre Calculator
