5 members (vincentvg, Gordon D, Mark Simmons, BrunswickGreen44, DaveW), 357 guests, and 43 robots.
Adam12 68
+8Rich 67
John V6 61
9,215 Registered Users
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,365
Posts813,378
Members9,215
Rbt Aero8, Salmon, stevends
Page 5 of 7 1 2 3 4 5 6 7
The rear spindle nut needs to be very tight, in the order of 160lbft tight. It's only the friction that the tension in the spindle creates that stops the spindle moving out of alignment. The adjuster screws and bars play no meaningful part in holding things in place against the forces generated between the drive belt and the tyre contact point; they bend really easily.if the nut isn't tight enough.
I'll stand by my description of the correct way to do up the spindle as "effing tight, then tighten till you can get the pin through the castellations."
JMD Offline
How on earth does a brand new M3W leave the factory and the dealer with the belt loose enough to be moved down by 2 inches ???!!
GregA10 Offline OP
Good approach wink
Those adjustment screws are clearly there to help space and angle it with the spindle loose, they’re nowhere near strong enough to support everything safely.
GregA10 Offline OP
Several possibilities:
1. Lunch
2. Pretty girl walking past
3. It’s 4:30pm
Quality control is put far behind in the order of priority. Money is heading the list with QC last on the list.
The older you get the longer the wrench handle you will need. I am just about hanging off the wrench to loosen/tighten that castellated nut from below with mog on lift.
That is how mine came as well, and I doubt the US dealer checked it
Rodger
2004 Plus 8 (wife's)
My brand new M3W had a severe pull to the right since brand new. After spending $500 for a local dealer to investigate and confirm, they filed a claim with Morgan, which never rendered any action or update. Finally fixed it with the Empire Suspension - the castor was off by 3.5 degrees. Go figure...
GregA10 Offline OP
Wow 😳
I long ago established that the amount of “passion”, “pride”, and “craftsmanship” car and bike makers proclaimed was inversely proportional to how well screwed together their products were 😅
British or Italian vs German for example.
Anyway, car was picked up around noon and Oakmere (dealer) called me around 4 to say she was ready to be picked up. Naturally it’s set to be pouring it down all day tomorrow...
And one of her not on a trailer...
Looking fantastic, have fun and drive it everywhere!
