8 members (Bishmog, Joske Vermeule, Sir Percival, Ian Wegg, +8Rich, BLUE+4, MJF, verysideways), 323 guests, and 37 robots.
+8Rich 64
Adam12 62
John V6 59
9,215 Registered Users
New
For saleWood rim moto-lita
by hugo - 30/07/25 04:28 PM
For Sale 2015 M3W - £23,000
by MOG42 - 29/07/25 06:28 PM
AC Cobra Rep. Vs Plus 8
Me Again
Tyre dates on Yokohama tyres
Aero 8 Maintenance
by mph - 29/07/25 09:24 AM
Moto-lita for sale
Moto-lita for sale
by hugo, July 30
2015 M3W for sale
2015 M3W for sale
by MOG42, July 29
Topics48,365
Posts813,361
Members9,215
Rbt Aero8, Salmon, stevends
Page 2 of 4 1 2 3 4
BGW #689372 17/02/21 10:44 PM
My money would be on dodgy relays too, been there, done that.
1969 4/4
1995 plus 8
2002 Aero S1
2013 M3W
2014 Plus 8
BGW #689391 18/02/21 07:36 AM
As relays have already been checked , I am with Budster and Max 5 on this: ignition key transponder or inertia switch..
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
BGW #689395 18/02/21 08:29 AM
BGW Offline OP
Thanks for your comments. I have checked the voltage at the pump and only seem to be getting 4.7 volts. I would have expected this to be 12.
I have checked all 3 keys and the transponder is in place.
The relays I have checked are a row of 4 in the aluminum fuse box under the bonnet.
I have pushed in the red button on the inertia switch and it seems to engaged.
I guess my next check is to run a direct feed to the pump and see if it runs. Should I do this by running a wire from the battery to the pump or is there an easier way?
Again, thanks for the help, please keep it coming as I am at a bit of a loss here!
Brendan
2018 Plus 4
BGW #689396 18/02/21 08:35 AM
Mine once had exactly the same symptoms, I did all the things talked about here and then tried the spare key, away it went, no problems since
Simon
2002 4/4
2021 Audi A1 sport
BGW #689399 18/02/21 08:47 AM
Try one of the other keys.
There is always the possibility that the immobiliser pick up next to the ignition switch has slipped (although doubtful if the car has been stationary).
'09 Gen2 MINI Cooper ragtop
BGW #689401 18/02/21 09:39 AM
Could the relay be faulty. I know you checked but try swapping it for one of the others. In the Roadster at least they are interchangeable. The low voltage seems to suggest it works but not totally.
2025 MG ZS EV aka Trigger
Mucky contacts on the reed faces within the relay, lack of regular switching & damp air in winter doesn't help
BGW #689418 18/02/21 11:54 AM
Exactly it is what happened to my S1 Roadster. What I didn't realise is that the fuel pump relay powers the ECU. That failed so whilst the dash lit up nothing happened.
BGW #689423 18/02/21 12:34 PM
For the uninitiated can you tell me where the fuel pump/ECU relay is located?
Many thanks.
BGW #689431 18/02/21 01:22 PM
On your car under the dash
Relays
Page 2 of 4 1 2 3 4
