2 members (Socalm3w, MOGDave),
200
42
Topics49,844
Posts837,360
Posts: 2,431 Likes: 17
Posts: 2,431 Likes: 17 |
My money would be on dodgy relays too, been there, done that.
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
Posts: 2,085 Likes: 69
Posts: 2,085 Likes: 69 |
As relays have already been checked , I am with Budster and Max 5 on this: ignition key transponder or inertia switch..
Posts: 38 Likes: 1
Posts: 38 Likes: 1 |
Thanks for your comments. I have checked the voltage at the pump and only seem to be getting 4.7 volts. I would have expected this to be 12. I have checked all 3 keys and the transponder is in place. The relays I have checked are a row of 4 in the aluminum fuse box under the bonnet. I have pushed in the red button on the inertia switch and it seems to engaged. I guess my next check is to run a direct feed to the pump and see if it runs. Should I do this by running a wire from the battery to the pump or is there an easier way? Again, thanks for the help, please keep it coming as I am at a bit of a loss here!
Brendan 2018 Plus 4
Posts: 521 Likes: 2
Posts: 521 Likes: 2 |
Mine once had exactly the same symptoms, I did all the things talked about here and then tried the spare key, away it went, no problems since
Simon 2002 4/4 1936 Austin 12 light 4 Ascot saloon 2023 AMG Mercedes C300e estate 2021 Audi A1 sport
Posts: 28,892 Likes: 350
Posts: 28,892 Likes: 350 |
Try one of the other keys. There is always the possibility that the immobiliser pick up next to the ignition switch has slipped (although doubtful if the car has been stationary).
Posts: 27,807 Likes: 749
Posts: 27,807 Likes: 749 |
Could the relay be faulty. I know you checked but try swapping it for one of the others. In the Roadster at least they are interchangeable. The low voltage seems to suggest it works but not totally.
Posts: 8,671 Likes: 489
Posts: 8,671 Likes: 489 |
Could the relay be faulty. I know you checked but try swapping it for one of the others. In the Roadster at least they are interchangeable. The low voltage seems to suggest it works but not totally. Mucky contacts on the reed faces within the relay, lack of regular switching & damp air in winter doesn't help
Exactly it is what happened to my S1 Roadster. What I didn't realise is that the fuel pump relay powers the ECU. That failed so whilst the dash lit up nothing happened.
Posts: 1,075 Likes: 1
Posts: 1,075 Likes: 1 |
For the uninitiated can you tell me where the fuel pump/ECU relay is located?
Many thanks.
On your car under the dash Relays
