0 members (),
256
94
Topics49,860
Posts837,485
Posts: 11 |
Could you please advise me the correct FO-MO-CO Oil filters fitted to the 2017 Mogan +4 2lt Ford D G I. Engine. 2006 Morgan 4/4 Ford 1800 Duratec Engine Thanks in anticipation Stuart K
Posts: 383 Likes: 6
Posts: 383 Likes: 6 |
Hi Stuart,
I see you asked a similar question at the end of October so have you angst over obtaining the correct filter? Everyone on here will try to help.
For the record my 2006 1.8 Duratec has an engine code CHBB so has always been fitted with a Ford oil filter ...... P F1751529 102096. There are many other manufacturers who can be used, Mann, Hengst, Mahle etc.
Hope this helps
Regards
Geof 70th Anniversary 4/4 (Duratec 1.8), model 1995
Posts: 2,092 Likes: 72
Posts: 2,092 Likes: 72 |
If you google a filter brand, most of them have a simple cross reference system available. Why not look at the details of the existing installed filters and find the equivalent from such a chart. Ford does not need to have a FOMOCO filter; there are many other reputable brands available.
Posts: 27,810 Likes: 749
Posts: 27,810 Likes: 749 |
I would get a Ford dealer recommendation & then ask a good motor factor.
Posts: 102 Likes: 1
Posts: 102 Likes: 1 |
Stuart For my 2018 Plus4 the original FoMoCo oil filter was a AA6E-6714-AA Last December BHM did a service (the car was still under warranty) and the new filter is a FoMoCo AA6E-6714-AB Will be interesting to see next time when the car will be out of warranty what filter they use. I believe the following are equivalents Bosch P7203 EAN: BOSCH 4047025654982 Fram FRAM PH9566 EAN: FRAM 2259118743440 Mahle ORIGINAL 70582038 EAN: MAHLE ORIGINAL 4009026887554 Hengst H319W Tim
Tim Plus 4 2018
Posts: 52 Likes: 1
Posts: 52 Likes: 1 |
Hi, Oil filter: fitted only my 2014 2.0 duratec GDI is a FoMoCo AA6E 6714 AA. equivalent is a Fram PH9566/Mann W7015 per Mann catalogue
Anyone got a suggestion on alternative spark plugs? Plugs fitted on my car is Ford: CYFS12Y1
Posts: 381 Likes: 3
Posts: 381 Likes: 3 |
When I first had my new Morgan serviced at the dealer he, I noticed the cost of the Ford filter was 2.5 times cost of purchasing myself from Ford spares.
Posts: 383 Likes: 6
Hi Stuart
I’m sorry I cannot help with you DGi filter Regarding the Duratec it is my understanding that 1751529 is the part no (shown on my local Ford garage invoice) and AA6E 6714 AA the oem no. Both are normally stamped on the filter housing itself (if ever doing a filter cross reference search use any/both numbers).
Cat302. What did the dealer say when he managed to get to his feet?
Regards
Posts: 381 Likes: 3
Salmo, I never informed the dealer, I have never returned.
Posts: 383 Likes: 6
Salmo, I never informed the dealer, I have never returned.  Yes, my preferred method, too.
Regards
