1 members (Saxonian), 142 guests, and 85 robots.
+8Rich 76
Topics49,861
Posts837,542
#690451 23/02/21 08:12 PM
Mr K Offline OP
Could you please advise me the correct FO-MO-CO Oil filters fitted to the
2017 Mogan +4 2lt Ford D G I. Engine.
2006 Morgan 4/4 Ford 1800 Duratec Engine
Thanks in anticipation Stuart K
Mr K #690469 23/02/21 11:01 PM
Hi Stuart,
I see you asked a similar question at the end of October so have you angst over obtaining the correct filter? Everyone on here will try to help.
For the record my 2006 1.8 Duratec has an engine code CHBB so has always been fitted with a Ford oil filter ...... P F1751529 102096.
There are many other manufacturers who can be used, Mann, Hengst, Mahle etc.
Hope this helps
Regards
Geof
70th Anniversary 4/4 (Duratec 1.8), model 1995
Mr K #690490 24/02/21 09:13 AM
If you google a filter brand, most of them have a simple cross reference system available. Why not look at the details of the existing installed filters and find the equivalent from such a chart.
Ford does not need to have a FOMOCO filter; there are many other reputable brands available.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
Mr K #690494 24/02/21 09:24 AM
I would get a Ford dealer recommendation & then ask a good motor factor.
Mr K #690555 24/02/21 03:44 PM
Stuart
For my 2018 Plus4 the original FoMoCo oil filter was a AA6E-6714-AA
Last December BHM did a service (the car was still under warranty) and the new filter is a FoMoCo AA6E-6714-AB
Will be interesting to see next time when the car will be out of warranty what filter they use.
I believe the following are equivalents
Bosch P7203 EAN: BOSCH 4047025654982
Fram FRAM PH9566 EAN: FRAM 2259118743440
Mahle ORIGINAL 70582038 EAN: MAHLE ORIGINAL 4009026887554
Hengst H319W
Tim
Tim
Plus 4 2018
Mr K #690608 24/02/21 07:18 PM
Hi, Oil filter: fitted only my 2014 2.0 duratec GDI is a FoMoCo AA6E 6714 AA. equivalent is a Fram PH9566/Mann W7015 per Mann catalogue
Anyone got a suggestion on alternative spark plugs? Plugs fitted on my car is Ford: CYFS12Y1
Mr K #690618 24/02/21 09:00 PM
When I first had my new Morgan serviced at the dealer he, I noticed the cost of the Ford filter was 2.5 times cost of purchasing myself from Ford spares. mad
Mr K #690626 24/02/21 11:24 PM
Hi Stuart
I’m sorry I cannot help with you DGi filter
Regarding the Duratec it is my understanding that 1751529 is the part no (shown on my local Ford garage invoice) and AA6E 6714 AA the oem no. Both are normally stamped on the filter housing itself (if ever doing a filter cross reference search use any/both numbers).
Cat302.
What did the dealer say when he managed to get to his feet?
Regards
Geof
SALMO #690660 25/02/21 10:25 AM
Salmo, I never informed the dealer, I have never returned. laugh2
Cat302 #690670 25/02/21 10:57 AM
Yes, my preferred method, too.
Regards
Geof
